Question about HP LaserJet 4L Printer
4L has died?
Printer has been extremely reliable. Suddenly a couple of days ago--no power. I checked the power cable and connected another, still nothing. I checked both fuses--they are good. I looked at the board and there's no evidence of a problem. Does anyone have any suggestions as to what to look at or is it finished?
Thanks,
LD
  • Anonymous Mar 30, 2008
    I HAVE THE SAME PROBLEM...BUT I HAVE NOT CHECKED FUSES...I HAVE 2 4L PRINTERS, ONE WORKS THAT I BOUGHT FOR 5 BUCKS, BUT THE PRINT QUALITY IS POOR..THE OTHER NO POWER..IT IS ONE I HAVE HAD FOR YEARS..HOW DO I CHECK AND CHANGE FUSES?
  • Anonymous Jun 08, 2008
    I had the same problem with the two printers I have (it happened right after I turn off the power off in the switch protector).
    Is a burial the only feasible solution?
    THanks
    Genius:
  • 3,587 Answers
Time to give it a decent burial..parts on those old 4L's are mostly drawn from others that are no longer functioning..
maybe you ought to have an HP wake, and a decent burial?
at any rate..that sounds like a power supply board went zonko..
Posted on Mar 21, 2008
I have an old Sony Trinitron that I bought in I believe 2003. Very reliable until a couple of days ago. Fell asleep watching, turned it off in the morning and now no picture. I hear it trying to turn
Unless you have some good electronics knowlegde, its time to can it. There is extreme high voltage to power tube sets. Plus the price of repair for a tv thats not worth much money nowdays.
I used to be a tv salesman.
Nov 18, 2012 | Televison & Video
Help please - last time I tried to use printer, 'on' light stayed solid green and nothing would work, however after 45mins approx it suddenly returned to normal and printed fine. Now sx115 is...
This could be due to various reasons.
1. Make sure that printer is connected directly to a wall outlet and not to any surge protector.
2.We can perform a cold reset or restore the printer to factory defaults. If the printer is connected to a network then make sure that we make a note of the network settings since the settings will not be the same after performing the reset.
Sep 10, 2011 | Epson Printer Accessory
Lexmark x4650 hi, I have plugged a in the printer, nothing happening at all , no indicator lights, it has suddenly died , last used it a couple of weeks ago , any suggestions ? thanks
Verify that the power cable is firmly connected into the printer. Plug the printer in to a different outlet, one that you have confirmed works (plug in a lamp to verify that the outlet works). You may plug in the printer without the computer connection to test this. Check to see if the printer has an additional power switch on the back near where the cable attaches. If the problem persists, verify that the voltage is correct with a multimeter. The output voltage should correspond to the DC Output value written on the adapter. Confirm that this voltage matches the DC voltage required by the printer as written on the underside model placard on the printer. If the voltage is incorrect and the adapter is the correct one for the printer, replace the power adapter. If the voltage is correct then there is a problem with the printer that requires repair service. You may want to consider a new printer if this one is not covered by your warranty.
Apr 02, 2011 | Office Equipment & Supplies
My LaserJet 4L just died. It worked one day, the next no power.
needs a new power supply board (common problem with this printer)
printerman007 at gmail.com
Sep 23, 2010 | HP LaserJet 4L Printer
Won't switch on.
Your expert reckoned it was definitely the mains cable, but in fact I bought a new one, still no luck, and the machine has definitely died it final death. I am buying a new A3 printer (some expense!).
Thanks anyway.
Jul 22, 2008 | HP DeskJet 1220c InkJet Printer
Screenwriter3 stalls at startup
I had a similar problem a couple weeks ago. We found that for some reason the printer was on "Pause" on our main network PC. This was of course effecting the whole network. Hope this helps!
Oct 05, 2007 | Xante ScreenWriter (Refurbished) Laser...
HP Laser Jet 4L - No Power
it's possible that the power switch alone just needs cleaning. Take it apart down to seeing the copper contacts and then polish the copper contacts with emory cloth.
Sep 09, 2007 | HP LaserJet 4L Printer
Power
Replace the power switch. A fairly standard switch type. You may get one off ebay or similar site. If push came to shove, you could just replace the power input assy.
Aug 13, 2007 | HP LaserJet 4L Printer
Printer suddenly dead
It's possible the power supply died, however, there is a 3amp fuse on the slide in power unit that could have blown. I would check it before taking it to the recycling pile. If you mess with it be careful around capacitors, they'll hold a charge even if not connect to power for several days.
Nov 24, 2006 | Canon BubbleJet i560 InkJet Printer
HP LaserJet 4L Printer Logo
181 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
