Question about Acme 5001 Supreme Juicerator Juice Extractor
Acme Juicer Supreme Juicerator 6001
Above item purchased in 1980, I need to have it repaired
motor hums and make strange sounds
    Champion:
  • 356 Answers
BEARINGS MIGHT BE GONE. OLD JUICER
AND SOME PARTS ARE NOT AVLB. OR
HARD TO GET. THEN AGAIN IT MIGHT BE
SOMETHING SIMPLE. MINE IS FROM 1990
AND I DO MY OWN REPAIR. NOT WORTH IT
TO PAY FOR IT.
Posted on Jun 30, 2009
SOURCE:
How do I remove top plastic round part from the rotor of the motor?
The manufacturer warrants that your Jack LaLanne Power Juicer is free of defects in materials and workmanship and will, at its option, repair or replace any defective juicer that is returned. The Jack LaLanne Power Juicer's motor is warranted for the lifetime of the original purchaser, and all other parts and components are warranted for 60 days from the original date of purchase. This warranty is valid only in accordance with the conditions set forth below:
1. Normal wear and tear are not covered by this warranty. This warranty applies to consumer use only, and is void when the product is used in a commercial or institutional setting.
2. The warranty extends only to the original consumer purchaser and is not transferable. In addition, proof of purchase must be demonstrated. This warranty is void if the product has been subject to accident, misuse, abuse, improper maintenance or repair, or unauthorized modification.
3. This limited warranty is the only written or express warranty given by the manufacturer. Any implied warranty of merchantability or fitness for a particular purpose on this product is limited in duration to the duration of this warranty. Some states do not allow limitations on how long an implied warranty lasts, so the above limitation may not apply to you.
4. Repair or replacement of the product (or, if repair or replacement is not feasible, a refund of the purchase price) is the exclusive remedy of the consumer under this warranty. The manufacturer shall not be liable for any incidental or consequential damages for breach of this warranty or any implied warranty on this product. Some states do not allow the exclusion or limitation of incidental or consequential damages, so the above limitation or exclusion may not apply to you.
5. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
If you want to order or have questions about specific parts or accessories, feel free to call us at our customer care department:
Phone: 1 (973) 287-5150
Procedure for Warranty Repairs or Replacement
If warranty service is necessary, the original purchaser must pack the product securely and send it postage paid with a description of the defect, proof of purchase, and a check or money order for $29.99 to cover return postage and handling to the following address:
Tristar Products, 500 Returns Road, Wallingford, CT 06495.
Sep 27, 2014 | Jack Lalanne Power Juicer 250 Watts
How to fix a E-1189 motor for jack lalannes juicer?
Jul 07, 2014 | Jack Lalanne Countertop Juicer PJP
Base motor
The Start capacitor in the motor is faulty or the centrifugal switch is worn out [email protected]
Jul 13, 2013 | Nutrifaster Ruby 2000 Juicer
Need spare part of "base
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370483745987
Hi SSalim, connect to the site above and make the seller an offer.
I hope that this helps you.
Feb 16, 2011 | Juicers
Motor is humming not working .. stoped in between juicer
it is jammed, or it is too full....stop, take apart, scoop out pulp, put back together and restart. go slow when juicing...too fast will jam it!
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
Apr 01, 2008 | Juicers
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Acme 5001 Supreme Juicerator Juice Extractor Logo
248 people viewed this question
Top Acme Juicers Experts
hawk630
Level 1 Expert
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
