Question about Brother MFC 210C All-In-One InkJet Printer
Faxing I can't figure out which plug do I plug the phone wire in to enable faxes to come in.
  • 667 Answers
The phone wire from your wall jack gets connected to the jack marked "line" on your printer. If you are also are connecting a separate phone to the printer connect a phone wire from the jack marked "ext" to your phone. Just in case you need a manual here is where you can download one. Please rate if this helped. Thanks. Have a nice day. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Posted on Mar 21, 2008
How do I hook up fax, and do I need a seperate phone # for the fax?
Plug the fax data line into your phone outlet. Plug your phone into the fax machine phone outlet. Follow the setup instructions to tell the fax when to answer. You can use the same phone line for both faxing and normal calls.
Mar 17, 2015 | Office Equipment & Supplies
My printer will not fax says not connected to network when it is.
faxing requires some type of Phone connection in most instances, network faxing is another set of drivers that need to run on your PC, the same as phone line faxing that utilizes your modem (as long as the modem is fax capable) the issue you have is the way it is set up. first off you have to have the communications between the printer and the computer running properly. If you do not have a router with a wifi connection and the printer is connecting directly to the computer wirelessly, you need to make sure it is set for peer to peer networking, if you have a true network using a router and wifi (more than one computer can connect to it, you need to make sure you are set for that. Remember, you are not faxing from the printer if it is not connected to a phone line, you are faxing from your computer. and you need to make sure you are running the correct type of fax software, for network faxing or dial up (phone line) faxing.
Jan 21, 2015 | HP Photosmart 7510 e-All-in-One -...
Will not send or recive fax
To test the fax setup from the product control panel, follow these steps.
  1. Press the power button (c01658021.gif ) to turn off the HP fax product.
  2. Wait 20 seconds and then press the power button (c01658021.gif ) to turn on the HP fax product.
  3. Connect one end of a two-wire telephone cord to the telephone jack and connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product. Figure 1: Two-wire telephone cord c01501963.gif Figure 2: Connect the telephone cord to the 1-Line port c01664685.gif 1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
  4. Make sure that there is plain white paper in the input tray.
  5. Press the Setup button (c01371950.gif ) on the product control panel.
  6. Press the down arrow (c01664686.gif ) to select Tools , and then press OK .
  7. On the Tools menu, press the down arrow (c01664686.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
  8. Review the report.
    • If the test lists faxing issues and solutions, the fax test failed. Follow the steps on the printout to troubleshoot the issue. This report is specific to your product and faxing environment, so use the solutions on the report to resolve the listed faxing issues. Repeat the fax test after fixing the listed faxing issues to make sure the test passes. If the HP fax product still cannot receive a fax, go to "Solution two: Make sure that the Auto Answer feature is turned on."
    • If the test does not show faxing issues and solutions, the fax test passed. Continue to the next solution.
NOTE: Click here (c00261105) (in English) for more information on interpreting the fax diagnostic test page. Solution two: Make sure that the Auto Answer feature is turned on The Auto Answer feature must be turned on for the HP fax product to receive faxes automatically. Turn on Auto Answer using these steps.
  1. Press the Setup button (c01371950.gif ) on the product control panel.
  2. Press the down arrow (c01664686.gif ) to select Basic Fax Setup , and then press OK .
  3. On the Basic Fax Setup menu, press the down arrow (c01664686.gif ) to select Auto Answer , and then press OK .
  4. Press the down arrow (c01664686.gif ) to select ON , and then press OK .
  5. Try to receive a fax.
Nov 02, 2010 | HP Officejet 5610 All-In-One InkJet...
Want receive a fax
To receive a fax, first check to see if your telephone line has the capacity to send and receive faxes, a "conventional modem" sometimes is necessary, that may have changed with VOIP . Make sure to configure printer for faxing and that the Fax icon appears in the Printer/Fax window.. Follow all the basic set up steps to configure Fax, making sure all options are set correctly to enable where required. You might call your local phone company and ask them what you need to hook up a fax capable printer...or ask the manufacturer for the specifics of configuration for faxing.
Jul 29, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
How do I accept or receive a fax??? I have the
Here's the User's Guide you can download from the Lexmark website to help you out with your faxing concerns. http://www.lexmark.com/publications/pdfs/x6100/eng/ug.pdf. Scroll to Setting up your All-in-One, Page 3, for physical connection guide. For faxing (sending/receiving), scroll to Faxing, Page 55, for your reference. Hope this helps.
Apr 13, 2010 | Lexmark X6170 All-In-One InkJet Printer
Fax
To test your fax setup
1 Press Setup.
2 Press 6, and then press 5.
This displays the Tools menu and then selects Run Fax Test.
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
3 Review the report.
– If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause faxing problems.
– If the test fails, review the report for information on how to fix any problems
found. For more information, you can also see the next section, The fax test
failed.
4 Press OK to return to the Setup Menu.
Make sure you used the phone cord supplied in the box with your HP all-in-one
to connect to the telephone wall jack. One end of this special 2-wire phone
cord should be connected to the port labeled "1-LINE" on the back of your
HP all-in-one and the other end to your telephone wall jack
This special 2-wire cord is different from the more common 4-wire phone cords
you might already have in your home or office. Check the end of the cord and
compare it to the two types of cords shown below.
If you used the 4-wire phone cord, disconnect it, find the supplied 2-wire cord,
and then connect the 2-wire cord to the port labeled "1-LINE" on the back of
your HP all-in-one. For more information on connecting this phone cord and
setting up your HP all-in-one for faxing, see Fax setup.
If the supplied phone cord is not long enough, you can extend it. For
information see The phone cord that came with my HP all-in-one is not long
enough.
● Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP all-in-one and check for a dial tone. If you do not
hear a dial tone, contact your telephone company and have them check the
line.
● Other equipment, which uses the same phone line as the HP all-in-one, might
be in use. For example, you cannot use your HP all-in-one for faxing if an
extension phone is off hook, or if you are using your PC modem to send an email
or access the Internet.
● The phone line connection might be noisy. Phone lines with poor sound quality
(noise) can cause faxing problems. Check the sound quality of the phone line
by plugging a phone into the telephone wall jack and listening for static or
other noise. If you hear noise, turn Error Correction Mode (ECM) off and try
faxing again. For information, see Use error correction mode. If the problem
persists, contact your telephone company.
● If you are using a digital subscriber line (DSL) service, make sure that you
have a DSL filter connected or you will not be able to fax successfully. The
DSL filter removes the digital signal and allows your HP all-in-one to
communicate properly with the phone line. Obtain a DSL filter from your DSL
provider. If you already have a DSL filter, make sure it is connected correctly.
Make sure your HP all-in-one is not connected to a telephone wall jack that is
set up for digital phones. To check if your phone line is digital, connect a
regular analog phone to the line and listen for a dial tone. If you do not hear a
normal sounding dial tone, it might be a phone line set up for digital phones.
● If you are using either a private branch exchange (PBX) or an integrated
services digital network (ISDN) converter/terminal adapter, make sure the
HP all-in-one is connected to the port that is designated for fax and phone
use. Also, make sure that the terminal adapter is set to the correct switch type
for your country/region, if possible.
Note that some ISDN systems allow you to configure the ports for specific
phone equipment. For example, you might have assigned one port for
telephone and Group 3 fax and another port for multiple purposes. If you
continue to have problems when connected to the fax/phone port, try using the
port designated for multiple purposes; it might be labeled "multi-combi" or
something similar. For information on setting up your HP all-in-one with a PBX
phone system or ISDN line
you may also refer to the manual for this unit here
if you go there please refer to page 82 of the manual or chapter 10
Aug 02, 2008 | HP Photosmart 2710 All-In-One InkJet...
MajicJack and faxing
1) I suspect a bad telephone connection, or connections are
being dropped.
2) Check the phone line wire. Unplug the phone line from the
fax machine, and plug it into an ordinary phone. Call a few
friends and check that the phone-line and the cable is
working. Make sure the line does not sound noisy, crackly
or drop out entirely. Jiggle the cable connectors as you do
this.
3) If the phone line is OK, then try faxing several different
numbers with a test message, to make sure that the problem
is not unique to a single destination, which would be a fault
at the receiving end.
4) If the phone line is good, and the all destinations are bad,
then the fax unit is defective.
5) If the problem happens during receiving only, make sure
you are not out of ink or toner, and that the paper is not
getting jammed.
Good luck, please rate my answers
Martin
Jul 16, 2008 | HP Officejet 5610 All-In-One InkJet...
How do I connect the wires for faxing?
there are two phone jacks at the back of the printer one is for line another one is for external device such as answering machine make sure you connect your phone line to the line jack at the back of the printer and try it should work. and also try to fax the right no.
Dec 12, 2007 | Lexmark X6170 All-In-One InkJet Printer
Can't receive a fax
Make sure the phone cord from the wall is plugged into the port in the back of the machine labeled "line" and NOT "phone"
Aug 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
