Question about Memorex MVD2040 DVD Player
Memorex MVD 2042
Whenever I insert a disc it reads " no disc".
  • sfergie2 Mar 01, 2009
    My DVD player reads no dics when I put in a disc
Me too. Only for Double Layer DVDs.
Posted on Nov 12, 2008
I Have a Memorex MVD 2047 DVD Player thats supposed to read DVD RW disks but it doesnt read them help?
Like you said the unit is capable of playing DVD RW and DVD-RW. However, some discs may not be compatible due to format of the files on the discs, software used and laser pickup. Some technologies used to record on discs can prevent optimal playback of the files by changing them which affects the ability of the player to read the file.<br /><br />If you are burning the discs, I would suggest you different software, make sure the video/audio files are being converted to a DVD format that can be played on stand alone players. <!-- from fixya rte -->
Aug 06, 2010 | Memorex MVD2047 DVD Player
My player does not play...All I have is a big blue screen. I put in the DVD but nothing happens The unit is model mvd 2042 Memorex
IF YOUR GETTING A BLUE SCREEN YOUR NOT PUTTING A SIGNAL OUT TO THE TV DO YOU GET A MENU OSD FROM THE DVD PLAYER IF NOT CK CONNECTIONS AND VIDEO SOURCE
Apr 30, 2010 | Memorex MVD2042 DVD Player
My DVD Pler loads but in aminute or so it says no disc
Try another disc, does this happen with all discs? the optics are most likely failing, did you try a DVD lens cleaner and also try canned air?
Mar 08, 2009 | Memorex MVD2042 DVD Player
Memorex m v d 2042 is locked
unplug for 5 minutes and it should reset itself!
Dec 17, 2008 | Memorex MVD2042 DVD Player
Memorex MVD 2042 DVD Player ''Key Lock on''
mt memorex dvd player says ``key lock on´´ and i don't know how to quit that and i can't opened with the remot control
Help please!!!!!
Nov 17, 2008 | Memorex MVD2037
My Memorex MVD 2042 won't open for me to insert a disk.
Mine did the same thing. I unplugged power, took off bottom ( seven screws on mine), took bar off covering lens ( two screws) cleaned rod that the door slides on with q-tip damp with rubbing alcohol. dabbed the rod afterwards with machine oil put everything back and now it works!
Nov 13, 2008 | Memorex MVD2042 DVD Player
DISK PROBLYN
When you get no disk error, that is because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others. Often the problem get worse in time.
Try first using a DVD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the DVD lens, or the whole drive unit.
Feb 07, 2008 | Memorex MVD2040 DVD Player
MEMOREX MVD2040 UNLOCK CODE
This is all I could find ..... Memorex DVD-2000 C/P / MVD-2020 / MVD-2022 / MVD-2027 / MVD-2027 A / MVD-2028 / MVD-2029 / MVD-2030 / MVD-2037 / MVD-2051
  1. Open the disc tray
  2. Press CLEAR
  3. Press 1, 3, 6, 9
  4. Enter region (0 = multi-region)
  5. Close the disc tray
  6. Turn the player off
Memorex MVD-2042
  1. Press OPEN/CLOSE
  2. Press 9, 7, 3, 5 (or 1, 3, 6, 9 for the "suffix B, C, D" model)
  3. The setup menu will appear
  4. Press RIGHT to move the cursor to highlight the regions
  5. Select region using UP/DOWN (0 = multi-region)
  6. Press ENTER
    (or try the instruction for MVD-2020 above)
Memorex MVD-P1072
  1. Turn on the player (without a disc inserted)
  2. Press SETUP
  3. Press 9, 2, 1, 0
  4. Select region (0 = multi-region)
Jan 16, 2008 | Memorex MVD2040 DVD Player
Memorex MVD2040 DVD Player Logo
211 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
