Emerson tv trouble shooting closed captions
The closed captions suddenly appeared on screen. I went to the menu and checked to see if they had been turned on and they were not. I've repeatedly turned them on and off via the normal method but they will not go away even though they are turned off.
  • Anonymous Sep 23, 2008
    i beleive that my captions were set on som sort of pre menu to my tv how do i get back to the ?pre?menu? window?
  • Anonymous Dec 17, 2008
    20 yr. old emerson t.v. and want to use the closed captioning feature but I don't remember how to make the closed captioning on the t.v.
I handed the remote back to my visiting 4 yr old granddaughter and asked her if she could make the words go away.......she showed me the "language" button on the cable remote and told me she likes to see the words so she can "read" them. Ya'll need a new "expert"? she works cheap.....red suckers.
Posted on Mar 24, 2008
Have numbers and letters on screen and wont go away, im able to see the picture but no sound sound from tv. these are the numbers that appeared on screen 058-0.06 271 A1 (top) 0F F6FD (bottom) and the...
U have the tv original remote wright?This problems likely parts of Close Caption problems.Look for a button that said CC on the remote press it make sure all like CC1,2,3.. to off should solved this problems.Or tries go into the main tv Menu looking for Close Captioning functions turn off to all CC1...and Text1... all to off.Will fixed this problems.
Jun 07, 2011 | Emerson EWF2004 20" TV
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
All of the sudden a large rectangular box appeared on my sony bravia
check in your on screen settings if you have closed captioning on.
Dec 09, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Jan 30, 2009 | Televison & Video
Have a black-out square appear on some channels especially FOX
GO INTO THE MENU AND TURN THE TEXT OFF. THIS IS ASSOCIATED WITH THE CLOSED CAPTION. CC1, CC2, CC3, CC4, T1, T2, T3, T4, OFF
Jan 22, 2009 | Broksonic TV
Black square appearing on tv
Nov 29, 2008 | JVC AV-27530 27" TV
Black box on screen
you have a closed caption type tv. Search your tv menu (maybe via the remote control) and look for an entry called closed caption, I'm guessing it is set to TEXT. either set it to OFF, or set it to ON if you want to.
Sep 18, 2008 | Emerson EWF2004 20" TV
Ctv 41301.... can't remove black box on the screen
A square box imposed on top of pix is called a text box.
It is controlled thru the Closed- Caption menu selection.
Enter CC menu and make different selections-try them all,it will help you to understand.....,..T.
Oct 05, 2007 | Craig CTV-41331 13" TV
Closed Captioning no longer works
check for the knub OSD on your remote to press it or at the menu select on screen display on
Apr 20, 2007 | Panasonic CT-27SF25 27" TV
Televison & Video Logo
1,413 people viewed this question
Top Televison & Video Experts
Electro Med Services...
