Question about Dryers
Kenmore dryer 11070842990 - Drum turns, but no heat. checked continunity on thermal sensors - OK. Door closed switch also checks OK. what's next?
  • rat8043 Mar 25, 2008
    Forgot to mention this is a gas dryer. But, I did find a thermostat in the lower right corner which is open.
    Local parts store has them on back order, so it will be a few more days before I know if this solves the problem.
    Thanks for the quick response.
    Scholar:
  • 178 Answers
Repalcing the heating element or thermostat. Small access panel on lower right side back of dryer will allow you to change these components out and be well on your way. Good luck.
For parts, look up www.marcone.com or www.partstoday.com
Posted on Mar 21, 2008
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
I have a Kenmore 800 model no. 110.69822801 dryer that stopped during a drying cycle. It would not start. I found helpful tips from your site and decided the door switch was faulty. I bought a new switch...
Check the thermal fuse, check the belt switch. If these are OK, check the timer. The timer troubleshooting guide may be located within the control panel. If the dryer still doesn't turn on, check motor winding continuity, and finally control board. Perform these checks with dryer unplugged. Most likely causes: Thermal fuse or timer. If thermal fuse is problem, clean dryer duct after fuse replacement.
Dec 18, 2014 | Kenmore Dryers
Replaced timer 696896 still does not move
It is most likely your thermal fuse. Check continunity with the thermal fuse disconnected. Otherwise it could be your door switch.
Sep 29, 2014 | Kenmore Dryers
Kenmore Elite Electric Dryer -- Diagnostic for electronic control "Start" touchpad is 09. What does it mean?
i donot know what 9is but i think its the moter switch or moter try switch first
Jul 19, 2013 | Kenmore Dryers
When I push the start button on my kenmore dryer it will not start and the drum will not turn
Several part failures can cause this symptom: bad start switch, bad door switch, broken belt, bad timer, bad thermal fuse, etc.
Most likely, the door switch or start switch is the problem.
Unplug the dryer! Check the door switch for continuity, when the door is closed, with a multimeter. If it does not have continuity when the door is closed, replace it. The start switch should have continuity only when it is pressed or rotated (as if trying to start the machine).
Apr 19, 2010 | Kenmore 63942 Dryer
Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Apr 21, 2009 | Dryers
Kenmore Dryer - no heat and timer doesn't stop
First turn off both breakers then back on. Next, check the wiring from the receptacle to the plug to the back of the dryer. Next, the thermal switch under the top of the dryer next to or near the drum may be bad. Bypass it and see if you get heat. If so, then replace it for about $20. Your heating element may be bad also. You can visually check it and see if it is burned in 2. Now your timer is probably bad. They are easy to replace and fairly inexpensive.
I guess after looking at all this, you need to decide if it is all worth it to fix it. If it is more than 10-12 years old, you may be seeing the beginning of the end. If the thermal switch, the element, the timer are all bad, you may want to make room at the curve and take the door off for safety. Dryers aren't that expensive especially when you consider the hassle. Good luck and let me know how and what you do.
Feb 11, 2009 | Kenmore Dryers
My Dryer will not start. Model 110.62802100 Kenmore
Does the drum turn when you press Start? If so, the motor is not bad.
I am having trouble finding a wiring diagram, but I can not find a moisture sensor in the parts listing. BUT, there should not be any wires just dangling, unless the are tagged as to their purpose.
I suspect one of the following (if the drum turns)-
1) Failed thermostat
2) Failed thermal fuse on heat elements
3) Failed over temp thermostat
4) Failed heat element
Please reply your findings and we can help further.
Jan 11, 2009 | Kenmore 62802 Electric Dryer
Kenmore Elec. Dryer Model 66912 (1996)
The problem is the motor switch . Try spinning the drum with the door switch held in and pressing the start button all at the same time .If the problem is lint in the switch that might be all you have to do . If that don't work you will need to replace the motor and no special tool required. I can walk you through it.
Dec 12, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Kenmore 62822 electric dryer
Check your heating element to see if it is shorted to ground.
The element has 110V to it all the time, so if the element shorts to ground it will heat all the time. This is a fairly common failure.
If the element is ok, you may have a stuck centrifigul switch inside the motor, this is very rare but does happen sometimes.
Post back to let me know what you find or if you have any questions.
Thanks/Mike
Dec 20, 2007 | Kenmore 62822 Electric Dryer
Dryers Logo
98 people viewed this question
Top Dryers Experts
