Question about Sony Ericsson K800i Cellular Phone
My hp pda wifi icon turns gree but will not connect to anything and says check your settings but i dont know how. Can you help me please
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 230 Answers
Go to the control panel and switch to the last tab - there's wlan settings.
Posted on Apr 21, 2008
My gree air conditioner turns off and turns on automatically during most of the time. what kind of problem is this? how can i solve it? in the owner's manual is not written anything like this...ca
its obvious that its the timer , some one has played with the timer settings , and now it switch on and off on the time set , i have this problem too, you need to turn off the timer , i dont know how to do it , this is the nasty thing about the gree AC's
Aug 05, 2012 | Heating & Cooling
How can i active my wifi??
The Wifi is set to enable from the factory. If you are sure the WiFi buttons is on and you still can not connect to a WiFi device, do the following:
1. Start > Control Panel > Mobile PC > Windows Mobility Center
2. Click the wireless icon located at the buttom left corner of the Windows Mobility Center.
3. Click Properties
4. Check the box next to HP Wireless Assistance icon in notification area.
5. Click Apply.
This will put an icon in your notification area (lower right of your screen). You are able to click this icon to turn on/off your wireless service as well as connect to networks.
Good Luck
C2Solutions
Nov 12, 2011 | HP NB199UA Pavilion Notebook
I am trying to get email access. I am not able to get my email even though my PDA says that it is connecting to my Wi-Fi
First you have to ensure that the problem is not from the internet connection. Try using the PDA and the same wireless connection to open a different site which is different from the email provider. If the other site opens then you are sure that the problem is from either the phone or the email service provider.
On the other hand if it does not open then this means that the recommended settings which are expected for the PDA to work with the wifi have not been properly set to give the PDA internet access. The device might be connected to the wifi but not connected to access the internet from the device. Try setting up the PDA and this time take care of the settings.
Hope this solution has been helpful?
Jan 08, 2011 | HP iPAQ H5550 Pocket PC
I cannot get any wifi connection. I purchased a Sylvania Netbook. I have followed the quick start directions. The wifi icon will not set up it shows off. I tried to set it up in two different wifi...
Please check whether you have the External Wifi Switch Turned ON. If it is Turned. Now go to Windows Mobility Center and check whether the Wifi feature is enabled.
If the Option is grayed out check whether the Driver is Installed and Enabled.
if the issue still persist, Please check whether the Wireless LAN Zero Confirguration Service is Started and set to Automatic/
Nov 17, 2010 | Sylvania G-Netbook
I cannot establish a working WiFi on my ASUS A639 PDA
You can simply follow the first 3 steps of this (http://iris.nyit.edu/oit/academic/FAQ/faq/2wireless/20026/20026.pdf) tutorial. After that, you should see your home wifi name in the list (as in the photo in the tutorial.). You should first connect to a network from this list (possibly with a wifi password), then it should connect automaticly evertime you swtich on wifi. After you have successfully connected to a wifi, you should see the wifi icon changes in the task bar. Hope this helps.
Apr 28, 2009 | ASUS MyPal A639 Pocket PC
Problems with HP iPAQ rx1950 Pocket PC not connecting to wifi
make sure your wifi is on for both devices, laptop and device. try to temporarily disable windows firewall to see if that is whyat causing the problem.
Since other devices are connecting then it is most likely the PDA that has the problem.
Is your devices set to use 802.11g technology, what possible WI-FI settings do you have in your device.
Mar 23, 2009 | HP Computers & Internet
Archos 5 wifi connecting problems
"hi have an archos 5, when trying to connect to wifi, keep getting "wifi error .(0)" or "wifi error .(21), i know i am in a wifi network area as my laptop and palm pda can connect ok, however the archos seems to keep scanning for networks until it eventually switches off, any suggestions would be greatly appreciated"
i have the same problem...PLEASE is there ANYONE who knows how to solve this issue.. my email is hbhuralal@gmail.com i need desperate help..
thankyou
Jan 06, 2009 | Computers & Internet
Hw6515 pda
Dear Phil,
its mean you have to update the GPRS Service.
there are 2 ways to downlaod the files, GPRS or internet
GPRS
1. click on the quick gps connetion icon, select setting.
2. select setting, then check the enable update and initial GPRS
3. click on icon and select download, it will connect to date service and download the files.
internet:
step 1 and 2 above
3. click icon select download while it on cradle.
also install the quick gps utility on pc, and add the quick qps connection into activesync list. each time you synchronize PDA the file will get updated.
For your second problem ,which is related to File Passward protections , its seems you had create these Worksheets on NTFS File system thatswhy they asked about the passward.
Regards
Mar 29, 2008 | HP iPAQ hw6515 Pocket PC
Wifi driver on iPAQ hx2490b
hi everybody!, In m,y case only updated the rom and ready. I hope that solve you troubles too.
Mar 29, 2008 | HP iPAQ HX2490 Pocket PC
Wi-fi PDA connectivity problem
First, restart your pda by using your stylus and pressing the pin-hole sized button on the back of the PDA. There are sometimes a couple of different reasons why the pda wont recognize the network. Main Reason: Make sure you are at the home screen... Tap the wifi icon on the lower right corner of the pda. T hen make sure that the WLAN power is turned ON. Press the setting button. If you see your network in the list, tap on it. It should bring up a network configuration window. Make sure it says it connect to "The Internet". Then tap on the "Network Key" tab at the bottom of window. If you have no security settings on your belkin router, make sure Authentication is set to Open and Data Encryption is set to "Disabled". Then press "OK". That should Be it!!!! Let me know if this way doesnt work, or if something doesnt make sence!
Sep 15, 2005 | Dell Axim X50v Pocket PC
Sony Ericsson K800i Cellular Phone Logo
23 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
