Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Kitchenaid model:KHMS105B microwave hood combination
Dear sirs,
this unit is 12 years old but always worked fine untill yesterday. when it was turned on it was normal for 5 seconds then it started to make shorting noise and the grease under the unit started to burn, luckily my wife saw able to put it out with no resulting damage.
I was wondering if the grease came in contact with the microwave lamp or the lamp went bad is the problem.
question #1 can this be repaired and Question #2 if the lamp can be replaced (if thats' the problem) and #3 does it pay to replace the unit because of it's age thank you for your help!
  • 53 Answers
Hi alan,
it sounds like the transformer is bad, which makes this easy, time for a new one. 12yrs is a good age for a microwave, average life is about 8-10 yrs!
Posted on Mar 21, 2008
SOURCE:
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
I have Kitchenaid Combination wall Oven and Microwave Model #KEMS308SSS and my microwave runs fine but dose not heat any thing and starts cooling for few mins
I have the same problem with a KEMS378 KitchenAid that is only 11 months old. Gettign warranty repair Monday...So can let you know...
Jun 20, 2010 | Microwave Ovens
Microwave will not turn on -- light does not come
Chances are good that you have a bad door switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 22, 2010 | Whirlpool RMC275PD Microwave Oven
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave
It sounds like there may be a blown fuse. The back of the mw oven will have to be removed to check. Some ovens only have a thermal fuse and not a traditional glass fuse. If that is the case you should call a technician to repair it unless you know how to use a soldering iron.
Dec 26, 2007 | Microwave Ovens
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
307 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
