Question about Cameras
I Charged My Battery And It Takes About 5 Seconds For The Battery To Die. I Charge It Agan And It Does The Same Thing.
  • 1 more comment
  • l_boro07 Nov 28, 2008
    I have a red samsung L100 digital camera and all of a sudden it would turn on for about 3 seconds and beep 3 times and then turn off. Although the power button would remain with blue light aorund it.
  • Anonymous Mar 15, 2009
    Same problem here. I Charged the batteries (have two). They hold about 7.25 V each. Camera says it needs 9.5V. Are both of my batteries bad? Are they not charging fully for another reason? Is 7.5V not enough for the camera to run on?
  • Anonymous May 03, 2009
    yeah ,samsung s800 piece of shyt camera, took a few pics and the batteries died , replaced them with some freshly recharged batteries . and same story , taking it back tommorow.
    Sniper:
  • 58 Answers
You need to replace the battery. Batteries have a finite life, and may die before they are time expired if they have gone through excessive charging cycles.
Posted on Mar 21, 2008
Pocket juice max 7800 mah cuts on then cuts off after 5 seconds with a full charge
sounds like your battery has lost its ability to charge. It could be damaged from either getting too hot, or dropping it. Age also takes a toll depending on the quality of your battery and the brand name also determines how long your battery will last if it is a rechargeable battery then it is limited to a particular amount of times being charged before it will no longer charge
Dec 07, 2014 | Cameras
More consuming battery every day i charged my galaxy s4
reset the phone to factory.
let the phone die.
charge the phone till 100%
when at 50 % charge again till 100%
let the phone die
Charge to 100%
Nov 28, 2013 | Samsung Cell Phones
Panasonic KX-TG6700 Phone
test the adaptar if working try it in another phone
2) sure the the line cord is plugged firmly in the phone base
3) unplugged the phone base . Wait from 30 seconds, and plug it again. Allow up to one minute for the cordless handset and phone base to synchronize.
4) charge the batteries by 16 hours aprox.
5) if the batteries is completely dead can take 30 minutes before low battery appears on the screen.if doestnot work replace battery by new ones.
try agan.
Oct 03, 2012 | Panasonic KX-TG6700 Phone
Once the unit is charged how long does the battery run dry
Once fully charged, it will last for about 4 hours, if it is used without shutting down. The good thing is that it comes with a rechargeable lithium ion battery. That can be recharged once it is weak. I will strongly advice that you do not allow the battery run down completely before recharging as the battery might become weak and unable to hold a charge. So do not let your gps die before recharging. you can charge once it is low.
Dec 24, 2010 | Nextar X3-03 Car GPS Receiver
My phone was working fine yesterday, It ran out of charge last night and when I put it on the charger thismorning it now just flashes white screen every 5 seconds or so ... is it dead ? cheers Wal
The phone should never be left to die out of charge anytime for good health of battery and phone.
So the problem is that the battery has completely died out so its not getting charged again, it bound to happen sometimes. So all you need to do is get it to a repair shop and just boost the battery initially so that it starts charging again.
Its similar to jump start in a car. So do not worry its a cheap fix only and never let it again to die out of charge.
Nov 21, 2009 | Sony Ericsson W850i Cellular Phone
Hi, I've had the vu for like seven months and it won't turn on
it means you have a fualty battery what you need to do is get a hold of a at&t store or carrier and get a new battery and that should fix you problem
Nov 04, 2009 | LG Vu CU920 Cellular Phone
Can't charge battery
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life. The best thing to do is contact your dealer, as I think you won`t be able to charge the batteries on your scooter as they will have no power. Thething with scooters is to put it on charge when not in use.
Sep 01, 2009 | Golden Technologies Compass Electric...
Phone will not hold a charge
Almost certainly you will have to spend $50 or $60 on a new battery. Assuming it has a removable battery, which most cordless phones do. Take the phone to Radio Shack and see if they have the proper replacement battery.
Jul 12, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Dec 14, 2007 | iRobot Roomba Red 4100 Bagless Robotic...
Phone says "charge complete" but then just dies
I took your suggestion and replaced the SIM card, but the difference is I managed to locked it in tightly. It worked.
Aug 21, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Cameras Logo
417 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
