Question about Sylvania 6842PE 42 in. HD-Ready Plasma Television
No power up on Sylvania 6842pem and your previous post.
Hello, With reference to; http://www.fixya.com/support/t138717-no_power_up I have the same problem that this user was having but I can not make sense of what is being reffered to in the post. I found and replaced the blown Cap but I could not find the one inch sqaure IC's being reffered to. I have a model 6842pe m. The sticker on the board reads LO652MSS. On the upper right left hand corner of the board it reads E234498 over L0650UA. I have the typical issue as described in the forum. when I turn on the TV it drops into standby mode after about 3 seconds. There is a flashing green LED (D2500) on the left side of the board and a relay clicks on the board when it goes into standby. There also appears to be a slight high pitch buzzing sound coming from the sub power supply board. I am reading 120 volts going to and coming from the sub board.
Any help would be much appreciated. Rick [email protected] You posted;
m1013
Rank: Guru
Rating: 87%, 81 votes
You actually lost a scan ic.Looking from the back,look at small vertical boards coming off the main y sus board.The ic's are about 1 inch square.Look for a small hole in one.Depending on the panel you might be able to replace the ic as an assy.
2 Suggested Answers
SOURCE:
  • 8 Answers
SOURCE: looking for info on Sylvania 6842 PEM
This RadioShack capacitor is no good - too low a voltage rating. Try replacing it with this one, or something with the same values:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=490-4260-ND
This fix worked for me. Best of luck
Posted on Jul 22, 2008
Still not working
assuming you mean the technics su-ch7 amplifier from your previous post
I have searched fixya and this forum below has been referred before on fixya previously for advice on your amplifier
http://www.allaboutcircuits.com/search?q=technic+su-ch7
and the original posting
http://www.fixya.com/support/t7155686-just_bought_tecnics_su_ch7_integrated
Mar 23, 2016 | Audio Players & Recorders
Sylvania LC420SS8 LCD set will not power up, no lights nothing, tried different plug ins no luck.
The power supply may have gone out, you need to check the main AC fuse in the power supply module and also check the caps.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or PANASONIC FM/FC series Low ESR, 105c, High ripple current and long life rating made for switching power supply from Digikey.com
Parts: www.shopjimmy.com
Please post back what you find.
Dec 06, 2010 | Sylvania LC420SS8 LCD TV
My Sylvania HDTV is in a standby mode. Can you tell me what could be the problem. The power will not come on.
Most problems are due to bad DC filter caps in the power supply module, that will be the first place to look.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Dec 03, 2010 | Sylvania LC225SSX LCD TV
Hi I have a sylvania 6842pem 42 inch plasma. when turning the television on it makes a weird screeching noise then goes to stand by. what can the problem be thanks for the help
your transformer on your power supply is bad, i would recomend replacing the power supply, usually when the transformer goes bad , it damages other things on the board, should be around a 200$ part
Jan 11, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Power Supply
No. They are entirely different. Panasonic was the supplier of the 6842PE and Funai was the supplier of the 6842PEM.
Oct 18, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania Power Board
I had the same issue. Turned out to be a blown capacitor on the power board.
<a href="http://s133.photobucket.com/albums/q68/rwlib3/?action=view&current=DSC_0426.jpg" target="_blank">
Jun 15, 2008 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Looking for info on Sylvania 6842 PEM
Mar 21, 2008 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Standby mode
It happened to me.. a FAx to Enrique. in California.
May 01, 2007 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
326 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
