Question about Advueu Technology ADV178T 17" Flat Panel LCD Monitor
Doesn't work its been working fine for yeats and suddenly it does not turn on, that power box along the cord does not light up when plugged in
  • Anonymous Mar 21, 2008
    same thing, first it would come on then go out, now it wont even turn on
  • 151 Answers
First you check power cord by multimeter for ok .if it is ok then open the monitor and check fuse in power section.If it is ok then check pf in power section.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 21, 2008
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My HP laptop (pavilion dv9700) will not start up. It was working fine then suddenly shut off while the cord was plugged in. The blue ring still lights up where you plug in the power chord, but nothing else...
Try the following:
  1. Unplug the power cord from the laptop.
  2. Remove the battery.
  3. Press and hold the power button for 10 seconds.
  4. Re-insert the battery.
  5. Plug in the power cord.
  6. Try turning on the computer.
Jun 07, 2011 | HP Pavilion dv9000z Notebook
At the base of cartridge carrier,on the right-hand side is a red flashing.It flashes along with the green light on the power-on button,and the blk and colour cartridge button.Struck by lightning.lexmark...
Hello. Hope you got working already. But if you're still having the problem, unplug the power supply (the small black box behind the printer where the power cord is attached) with the other end still plugged in to a known working power outlet. Look around the black box, it should have a green LED on around the silver contacts. If not, properly secure the power cord by unplugging and plugging it back in. Otherwise, you got a defective power supply. Try not to use extensions or power strips, plug printer straight to the wall power outlet or plug it to a different known working power outlet. If the power supply is working fine, plug it back in the printer in a correct position. Properly insert it and make sure it pushed all the way in the printer. If you're still getting all blinking lights once plugged in, your printer might be damaged by the the lightning strike. If that's the case, you can call Lexmark and ask for assistance with that. Well, these are the troubleshooting steps you can do to determine where the problem is. Good luck!
Mar 20, 2010 | Lexmark C530dn Laser Printer
Looking for a power cord
Hi guys,
Had the same problem yesterday. Went to Radio Shack and picked up a universal power adapter (Model 273-1696). It can be set for 6V and will draw the required 2000mA. Box does not include the right size plug, but the salesman gave me one that fit for no extra charge. Cost 32.99. Everything is working fine now.
Jul 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Laptop was working fine, but doesn't turn on anymore...
a5e3d98.jpg You might have a Loose DC Power Jack.. Or.. if you're using the same AC Power cord for both laptops that you tested, you apparently have a break(short) in the Power charging cord which is quite common...
To Test the cord..take the battery out and try to boot with just the AC power cord plugged in, If it does'nt power up, try turning and slightly twisting the plug into the port.. LOOK to see if the power light is on or flickers...
Jun 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
360 No Longer Turns On
By cord, do you mean the entire AC convertor box? Does the orange light on the convertor box light up? If you used your friends whole ac wire/convertor box (w/ the plug that goes into the xbox itself) and THAT didn't work, then your motherboard took a surge. It is probably trashed as they are VERRRRRRRY sensitive and prone to failure. Time for a new one (or a warranty "repair").
Sep 12, 2007 | Microsoft Xbox 360 Console
Advueu Technology ADV178T 17" Flat Panel LCD Monitor Logo
88 people viewed this question
Top Advueu Technology Computers & Internet Experts
David Payne
David Payne
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
