Back to:
Tags:
Ibico 1202 Calculator
Adding adding machine paper to the Ibico 1202
posted by ursulina on Mar 21, 2008
How do you put the adding machine paper in the Ibico 1202?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 21, 2008
Not Rated (0)
TheMacGyver
Rank:Guru Guru
Rating: 91%, 127 votes
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Please remember to leave a rating or feedback if I have helped you with your question.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Adding adding machine paper to the Ibico 1202:
I don't want to Accept this solution
Can you Help with these Calculators problems?
Calculators
Quiero traspasar texto de mi pc a la calculadora , cargue...
Calculators
1. If a soccer lover has a photo frame that is 180mm in...
Calculators
hi i purchased a fujitsu g820 and it has the previous...
Calculators
i have a canon p23-dts II calculator but i have lost the...
Calculators
I have a Sharp EL-506G scientific calculator that has...
Loading problems.
Repair Service
Find Calculator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
