Question about Hitachi 43UWX10B 43" Rear Projection Television
I hit the accept key without resolution after paying for online assistance
Hello I am having problems with the white green and pink or red not lining up properly. I opened the back and found a resistor rk58 that measures .5214 Mega Ohms. The resistor is discolored so I can not tell the rating of it. I would also need to know the ratings of the other associated resistors. Any help would be great.
  • Anonymous Mar 24, 2008
    I did the same thing I tried to line up the lines for color. Then hit the resolution button it lined up for a few minutes. Then it messed up again what needs to be done.
    Guru:
  • 731 Answers
Hi
>>Does the chip STK392-120, looks burned.
if yes, replace it.That will fix the problem.
>>There are two IC's, a 392-150 will be the best replacement, and if there are any large burned resistors on that board (should be pretty obvious), then they need to be replaced, too. If there are , let me know the board designator number (it will be "RK-XXX")
Thanks
Riz
Posted on Mar 21, 2008
SOURCE:
Wiring coming out of motor doesnt match wiring harnesses that I have purchased
It is not the replacement you need! Go back and get the correct replacement item.
Sep 02, 2017 | Cars & Trucks
I need the stereo wire schematics for a 1995 ford aerostar xlt
1995 Ford Aerostar Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 3 1/2?
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
if you need further assistance please let me know. If this helped solve your problem then please feel free to rate it accordingly. Thanks, Midwest-tek
Aug 31, 2010 | 1995 Ford Aerostar
Im trying to figure out the wiring system so i can conect my radio cd player on toyota yaris 2002
Hello! Here is the wiring for your vehicle...There are more than one color listed for certain connections...Simply look for the one you have...
POWER
Switched +12= Gray or White
Constant +12= Blue/White or Light green
Illumination= Green and White/Green or White
Ground= Brown or Pink
SPEAKERS
Left Front= Pink and Violet
Right Front= Light Green and Blue
Left Rear= Black and White
Right Rear= Red and White
Guru........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jun 02, 2010 | Car Audio & Video
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
I'm installing a pioneer deh- 2750mp cd player into a '92 Ford Laser, and was wondering how the wire colours match up?
Hello! Ford wiring
Power
Constant +12volts Green/Yellow
Switched +12volts Yellow/Black
Ground Red
Power antenna Blue
Illumination Blue/Red
Speakers
Front Right + White/Green
Front Right - Green/Orange
Front Left + Orange/Green
Front Left - Light Blue
Rear Right + Pink/Blue
Rear Right - Green/Orange
Rear Left + Pink/Green
Rear Left - Pink/Blue
Guru..............saailer
Jan 22, 2010 | Pioneer DEH-2700 CD Player
Radio works just have no digital read out on 1999 explorer. Is it fused related?
Hello! Yes It could be fuse related. You have lost power on the Blue/Red lead, which is illumination to the radio.
If you have a multimeter you can look for +12volts on this wire with the key on. If it is not present; Check fuse #27 15amp inside drivers side fuse box.
In case you ever need the entire wiring; Here it is...
Green/Yellow memory +12volts with key off
Yellow/Black ignition +12volts with key on
Red Ground
Blue/Red +12volts with key on
SPEAKERS
FR + White
FR - Green/Orange
FL + Orange/Green
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Guru...................saailer
Jan 12, 2010 | Bose Car Audio & Video
1994 mercedes 500sl dash cluster problem
Hello, I don't have a picture but maybe this will help,
red/yellow-4
brown/white-1
brown-2
blk/yel-2
pink-11
green/white-13
green-12
brown/red-18
brown(small)-17
blue/brown-10
blue/green-7
blue/white-14
3 5 6 8 9 not used
I hope this will help.
CYA Gator241
Dec 08, 2008 | 1994 Mercedes-Benz Mercedes Benz Sl Class
My rca d61130 projection tv has red/pink faint lines
It sounds as thought he convergance needs to be adjusted. You will need to push the auto adjust button or go into the menu and do a manuel adjust. Any adjusting instructions should be listed in your Operator Manuel. If you require more assistance in this matter, please write back. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | RCA D61W20 61" Rear Projection Television
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
