Question about Kenmore Elite 45986 Front Load Washer
Error F 01
I cancelled the load in the middle of a wash cycle in order to add another garment.  Now it won't let me resume, and the display is flashing F01.  Did I break my machine?!
  • 185 Answers
Whats the model number please
Posted on Mar 27, 2008
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
Jan 16, 2012 | Whirlpool GHW9300 Duet Washer
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Kenmore h2 error code
Jan 11, 2010 | Kenmore 46462 Front Load Washer
I hit cancel in the middle of a cycle and now it keeps saying F1
From the maytag website:
To remove the error display, press Power/Cancel or Pause/Cancel twice.
If Power/Cancel or Pause/Cancel does not work:
Unplug washer or disconnect power for one minute.
Plug in washer or reconnect power.
Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, call for service.
Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
60 people viewed this question
Sal De
fordexpert
Robert Rankin
