Question about Microwave Ovens
Microwave fuse keeps blowing
I have a Sharp Carousel 1000watt microwave. I couldn't find the model number. It lost power and I opened it up to check the fuse. I replaced the fese with a 250v / 20 Amp fuse. It powered on and I was able to set the clock. As soon as I tried to run it for a test, it blew the fuse. Any suggestions or "flow chart" advice would be helpful. Thank you.
  • jmcardle6 Dec 27, 2008
    My micro. blew a fuse while cooking. I replaced the fuse and programmed the clock. when I try to cook, the fuse blows again , what is the next step in t/s this problem?
Ckeck your door switches and h.v doides if you know how if do not get serviced by technician
Posted on Mar 21, 2008
SOURCE:
Magnetron part for a sharp carousel Microwave oven Model R-930ak
Maybe a faulty magnetron but check for abnormal noise caused by faulty diode pack. If you are in UK google the part number
RV-MZA114WRE0
R930AK Sharp Sharp Microwave
Apr 07, 2017 | Sharp Microwave Ovens
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Oct 14, 2009 | Sharp Microwave Ovens
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
Sharp Carousel Model#4A58: was cooking & made
If you have no power what so ever its probably the main fuse inside the mirowave. You'll have to take it apart. If you try this yourself unplug it then there are several screws around the cabinet of microwave remove them and make sure that they go back where you took them out from because they may or maynot be the same size or length. once you get the cabint off follow the plug wire up into the micro wave there may or may not be a fuse on the wire just inside the frame of the Microwave but it will be close when you find it take it out and replace with the exact size take it to a appliance parts store and get the replacement.
Sep 03, 2009 | Sharp R-4A58 Microwave Oven
Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
Jun 11, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Microwave Ovens Logo
502 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
