Question about Lexmark F4270 Plain Paper Inkjet Fax
Won't recieve a fax
Everytime someone wants to send me a fax, it states that it has failed, and I can't seem to find the problem. I bought the printer in walmart and now they no longer sell the item.
When i try to received a fax the page is blanc
Posted on Mar 27, 2008
  • Anonymous Mar 27, 2008
    I have a 4270 Lexmark when i try to received a fax everyting goes ok i connect and the fax comes thru but the page is blanc and they mention it could be the black ink.
    does anybody no if this is true.
    Egui.
    President:
  • 2,072 Answers
Normally a receive problem is in the phone line. I will explane so you understand why I am saying this and not excusing the machine.
For starters as a resoution, make sure your phone line is plugged into the line slot and not a slot for a phone or answering machine. The slots I am talking about are on the fax machine.
Also if you have the fax on the same phone line with another device. An answering machine, a credir card reader, etc etc, make sure there isn't a conflict. Try just plugging the fax machine into that phone line.
Now to explane. When you send a fax, you manually turn on the phone line when you tell it to fax, Pressing that button energises a relay and just like picking up your phone receiver you turn the phone line on phisically.
When you receive a fax, it has to have the proper signal to electronically activate the fax/modem board.
Issues can be as simple as a bad phone cord between your fax machine and wall jack. They do build up resistance and cause problems.
3 issues are needed to receive a fax. The phone line Voltage must be correct, the phone line current must be high enough and there must not be a decibel loss.
A good example is a remote controle. You have old batteries. Well if you measured the voltage, it would still be 1.5 volts, but it can not deliver anough current to change a channel or adjust the volume all the time. If the line voltage is right, and your phone line it having a problem, it can't deliver enough current to turn on the fax, like turning on a TV with a remote, there is just not anough total power to activate it.
Remove everything else but the fax from the phone line, try it then.
Replace the cord between the machine and wall jack, Try it then.
If that doesn't correct it have the phone company test your line to the house, if thats ok, then repalce your wall jack.
99 percent of the time a phone line will be a problem.
Posted on Mar 21, 2008
  • Rick Kasper Mar 21, 2008
    Well if this is in a business, have them check the phone line to the business. It won't help to fix the house line if the machine isnt there LOL. Sorry my sarcastic sense of humor had to add that....
6ya staff
SOURCE:
CAN T RECIEVE A FAX FOR SOME NUMBERS BUT CAN SEND THEM ONE WHY
I've seen this many times before, when a customer / account gets a new fax machine, or is using a different fax machine. All the other faxes go through without a hitch, except for these. If fax machines become a couple generations apart / 10 years, they won'
t communicate sufficiently enough to make the fax hand shake and the Fax fails to go through.
Jan 29, 2015 | HP 7210 OfficeJet All-In-One Printer
With my epson 520 i can recieve faxes but i can't send them.. everytime i send one it says no answer but i verify that the fax line im sending it to does work.
Hey I had this issue as well with my FAX and I validated that my setting were good and I'd even hear the Fax line pick-up and get a "no Answer" error. I went into FAX settings and just turned something called TCM off and then it worked. Maybe it is for sending it to an older Fax machine, but I did get it to work!
Dec 05, 2010 | Epson Stylus Multifunction Printer/...
Recieve error 334 when sending fax but i am able to recieve faxes
Error Codes: 332, 333, 334, 335, 336, 337, 338 ECM, 339 ECM, 340 ECM, 341 ECM, 342 ECM, 343 Definition
The remote fax machine might be defective.
Solutions
  • Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
  • If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
Error Code: 334
Definition
Solutions
Sep 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Faxing from scanner rather than feeder.. help.
ideadly the scanner needs to scan to get the image to send out in fax form. The feelder paper feeder that is for recieving fax
Jul 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Same problem
press the setup button and scroll down to tools.
in tools there should be an option that says run fax test.
that would give you a printed page as to which part of the hardware of the printer or the fax line failed.
What your error code means is(look below)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jun 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Fail to send and recieve
Well it was fixed after I called our telephonecompany.
They told us last Thursday that the lina was ok, but yesterday I talked to a extremely competent callcenteragent and he could confirm the problem lay in the connection.
So, it wasn't a problem wit the JX200 after all.
Jun 03, 2009 | Canon FAX JX200 - Fax / copier - ink-jet...
I can send fax but cannot recieve one it just rings
My Mode was wrong. I switched it to telephone and fax (instead of manual). Then i set the ring to pick up on the third ring. now i dont have to be here to press start everytime a fax comes. I found all the information by searching for the manual on line it is under "Basic fax settings"
Mar 19, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
MFC 7840W, fax not sending or receiving
Is your phone line DIGITAL? Fax machines are ANALOG devices.
Jan 15, 2009 | Brother MFC 7840W Printer
Can't get fax set in recieve mode
Please state your make and model. Each make/model has different method of setting.
Jan 08, 2008 | Office Equipment & Supplies
Lexmark F4270 Plain Paper Inkjet Fax Logo
133 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
