Question about Canon PIXMA iP2000 InkJet Printer
Only prints black & blue
I replaced my colour ink cartridge and tried to print but I only got blue. Cleaning the nozzles didn't work so I bought a new cartridge and that one only prints blue as well. So I think it might be a problem with the printer. Help! Is there anything I can do to fix the problem?
  • colm19 Apr 17, 2008
    I ended up taking out the print head and soaking it in hot water a couple of times. It took awhile but eventually I got the color back.
  • Tallrite May 25, 2008
    Exactly the same. My printer prints only black and blue, though I have replaced the colour cartridge twice and tried both cleaning and deep cleaning, all to no avail.
I have a similar problem - i can print all colours apart from red.
I've tried cleaning, deep-cleaning, and even bottom plate cleaning but of none if this improves anything.
Tried cleaning the print heads and nozzles with cotton buds, but this dont do anything. Even tried re-seating the cartridges but this does nothing either
Posted on Apr 16, 2008
What is the cause of new cartridges running out of ink while checking trying to align print head?
You must replace the print head., as long as printer detecting that nozzles are not firing properly., it keep on cleaning the head, result it will drains the inks from the ink tanks...once you replaced both print head & tanks, take print outs at least twice in a week., perform nozzle cleaning once in a month to avoid this type of nonsense..
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
Epson xp 305 help
It's quite likely that at some point in time you will have attempted to print in black only to receive an error message that you cannot print until a colour cartridge is replaced.
"If ink is not in the tubes from the head to the cartridge, air will be sucked in and therefore cause damage to the print head. This is because the nozzles are in the print head and not in the cartridge. "
What Epson are basically saying is... if this safeguard was not in place, and you sent a print request for black when a colour cartridge was empty, there is a risk of air being pulled into the printhead. This air will ruin the vacuum effect needed for the printhead to pull ink in, meaning your printhead would be at risk of never printing again.
Additionally, if any air is allowed go get into the aformentioned tubes from the head to the cartridge, any remaining ink will coagulate. Just in case you're not a scientist - coagulation in a tube/cartridge is bad, and will lead to you not being able to print again with that cartridge, or to a blocked nozzle/printhead which will require a significant amount of cleaning cycles to budge.
Aug 08, 2014 | Epson Expression XP-305 Inkjet...
Canon pixma ip1000 print black colour with gaps.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jan 23, 2014 | Computers & Internet
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
I have an HP Photosmart D7560 printer. It worked fine until it was left with no cartridges in it for a few weeks. Put in 5 new cartridges and it would only print black. Tried various head cleaning and...
You may need to clean them manually. Take out each cartridge, clean its electronic panel with tissue soaked in a bit of methylated spirit. Also clean the area of contact in the carriage for each cartridge.
If patiently and carefully done all the colours will begin to print; so long as they are still flowing at the nozzle (not dried at the nozzle). To check if they are not dried at the nozzles, apply folded tissue to each cartridge nozzle and press gently, upon removing it, it should come out well/stained with the respective colour. If not you should place in a saucer or plate with a bit of water. Leave for about ten minutes. Then apply the folded tissue again. Ink should blot it well now. If not it means your ink is dried out and you may need to replace that cartridge.
Good luck and God bless!
Nov 13, 2010 | HP Photosmart D7560 InkJet Printer
Brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
I have recently bought new ink for my brother mfc 255cw. While it was running low ink, it would print out copies colored purple. even though I have already purchased and replaced all the ink cartridges, it...
I would suspect your inkjets are blocked Black and blue =purple so the other colors are blocked up Use the nozzle cleaning function to try and remove the clog Run nozzle check after cleaning mode till all colors print correctly
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Office Equipment & Supplies
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Only one colour showing at time of print
Maybe the ink well nozzle area has some dried ink left from the old cartridge. Remove the new cartridge carefully, and using a wet Q-tip,clean the area. Replace back the new black cartridge.
This worked for me ....good luck !
Sep 29, 2006 | Epson Stylus C64 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
157 people viewed this question
old marine
old marine
