Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Faxes only top of page center is blank
When faxing only top and bottom of page is sent middle which is hand written is blank
  • 682 Answers
Change your resolution from fine to super fine and make a copy to verify your fax machine"s scanner operation.
Posted on Mar 26, 2008
How do i find out the location from where a fax has been sent from whilst i have there fax number ?
Hi! Somewhere, either on the header or footer of the FAX or on the Cover sheet should be listed the name or company of the sender, his/her phone number, the computer id, the time and date and the fax number. If you received a FAX where all of this information is missing, it may be from a scammer. There should be some sort of ID. Look carefully at the top and bottom of each page. Hope this helps.
Nov 28, 2012 | Office Equipment & Supplies
The faxes being sent print out with vertical lines down the middle
There is a little scanner in the fax machine that reads the page so it can be sent out. You should be able to open the top, similar to changing the toner, and locate the scanner. This should have some glass over top protecting it. Just take a damp cloth and clean that piece of glass. There is most likely a small piece of dirt on the glass, but when it scans paper it looks like a big streak.
Jan 10, 2011 | Samsung SF-560 Plain Paper Laser Fax
My faxes are being received as blank page, why?
make sure the faxes you send are face down in the feeder, if you can read what you are sending they will be sent blank
Aug 17, 2010 | Brother IntelliFax-2920 Fax
Outgoing fax was received as blank
Make sure that you sent the fax face down.
If all your faxes are sent blank, there may be a problem with the scanner. Try making a photo copy placing the page face down, if your copy comes out blank then the scanner is finished.
If your photocopy does not come out blank then the problem is on the other end and not your machine.
Thanks,
Pat
Aug 16, 2010 | Brother IntelliFax-2820 Laser Fax
Receive coversheet followed by blank pages.
Confirm that the sender did not insert the pages to be sent upside-down in their fax machine. This will give you blank pages. Otherwise your fax may have a memory problem.
Feb 18, 2010 | Brother IntelliFax-1860C Plain Paper...
Fax is sending blank page
Make a copy on the machine to be sure it is not a problem with your fax machine nor that the original is being sent upside down. It is very rare to be blank. Black faxes indicate a bad scanner assembly.
Dec 26, 2009 | Samsung SF-560 Plain Paper Laser Fax
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Vertical blank strip
clean the roller and the cartridge head with alchol.
Jul 18, 2008 | Canon FaxPhone L75 Plain Paper Laser
3150 fax machine outputs a blank page when my fax sends to it
(05) Would you, please, SEND a fax from the machine that blank faxes are being received from to a different recipient on a different fax machine all together, please?
This will enable us to pin down which machine is really experiencing the issue.
Thank you
BJ @:)
Apr 17, 2008 | HP LaserJet 3150 All-In-One Printer
Fax Numbers-Memory?
Unfortunately that is a function of the sending unit. If they did not program their number in, then you won't have a record. If this is a persistent problem, you may want to sign up for Caller ID. Even if they put the paper in upside down, your fax will still print a head on top of the page with the information they have programmed. If they program a wrong fax number, then all you will have is a wrong number. Wish I have better new for you. Ed
Jun 13, 2007 | Muratec M1250 Fax
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
54 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
