Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
Top And Bottom Of Screen
I can not seem to adjust the screen so you can see the sports tickers and scores that are normally on the bottom of the screen. It's like everything is zoomed out. Please e-mail me at " " if you have the solution to this. It is a 50" Panasonic Plasma.
  • joe_kate May 14, 2008
    Same exact issue.
    Any resolutoin?
If you have HD service your digital box will change it according to signal format also with HD service you seperate channels with diffrent formats
Posted on May 17, 2008
  • 146 Answers
If you are useing a cable box or satelight rec. Check the format that you have it adjusted to. If not adjuste the format of the tv. If that does not fix it, it will need to be adjusted by a tech.
Posted on Apr 23, 2008
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
I'm watching football and cannot see the top score
You should adjust the aspect ratio on your cable box. Depending on your cable company there should be an aspect/HD zoom button. If this does not work go into the TV settings using the "menu" button and try to find a reference to aspect. Make sure it's set to 16:9 normal vs. stretch. You can contact Total COntrol Remotes ( for help with this kind of issue.
Sep 06, 2009 | Vizio 42 in. LCD TV
Horizonal and vertical off.
My picture is too big for my screen also, I have a 27 inch screen and I can't see the scrolling tickers on the bottom and the baseball score readout on the top. When I turn the tv on, the heads are huge on the top and that finally comes into proportion, but it goes too far. I can't find a horozontal or vertical control in the manual or on the tv menu. What can I do?
Apr 29, 2009 | Curtis-Mathis CM27101S TV
Screen size
Nov 02, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Screen adjustments??
On the remote, if you use the right and left keys on the pad with the OK sign in the middle, it will adjust the screen to several sizes including Cinema, 16:9, 4:3, Zoom, etc. I, personally, use 16:9 because I, like you, need to see the ticker symbols at the bottom. I hope this helps.
Sep 17, 2008 | RCA HD56W58 56" TV
Picture adjustment on zenith SM3247MK8
Probablemente tengas problemas en el circuito vertical o los capacitores adyacentes hay que checarlos.
Mar 20, 2008 | Televison & Video
Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Oct 21, 2007 | Televison & Video
Wacthing sports -Tickers and scores are off screen in HD
skilled,senior tech needed to access servicer mode and check/adjust geometry/convergence. if unresponsive,then replace convergence and re-check geometry and alignment.
Sep 30, 2007 | Sony KP-51WS510 51" Rear Projection...
Sharp 42In
Go to the Menu
Select Setup
Select Position
Select V-POS and move the slider to the right.
If you do this when the score scroll bar is on the bottom of the screen you can make the adjustment to suit your needs.
Sep 21, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
194 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
