Internet connection dis connects
I have a dsl router and it keeps disconnecting all the time!
  • GurraG Jul 27, 2008
    My DSL connection allways sets up correctly and fast.
    However my Lan connection never comes up.
    I have change to another modem, same behavior.
    I have changed ethernet cable and also to cross-over, same behavior.
    I have tried with another laptop, same behavior.
    Could the ISP or DSL connection influense the LAN connection?
    Please advice, I'm going mad.
  • Jyackle5
    Jyackle5 Dec 15, 2008
    My deak top can get on ok but about 5 mins latter I get disconnected. would like to get help on why. Thanks Jon
Got new moden
Posted on Mar 23, 2008
Why does my internet keep disonnecting
Install Router Commander. This program can optimize router settings and speed up your internet connection. The other good thing about this program it protects router from overflow and you connection did not disconnects.
Aug 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
The internet connection is fine (DSL AT&T).
1. You may have a an IP address conflict.
2. check the device connected to the router
all computer need to be connected at the same time.
3. Bring all the computers up one at a time and this should resolve the address conflict.
May 16, 2010 | Linksys WRT54GX4 WIRELESS 802.11G...
Internet connection keeps on dropping
Can't seem to find the manual on it but....
Most DSL/Routers have a connection setting in them with 2 settings.
1) On demand (Connects to internet as needed)
2) Always on (Stays connected to the internet)
Sounds like your DSL/Router is set to option 1
Apr 28, 2010 | Zyxel G-4100 v2 802.11b/g Wireless Access...
I don't know how to connect my router. please help
If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
Connecting DSL/Router to DIR-628 internet router.
it is possible but the routers have to be on separate channels
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Linksys routetr problem
HI,
The problem can be caused, because of two reasons, one the router profile on the computer has got corrupted and second the router itself. Have you tried resetting the router to factory defaults.. Caution: all wireless security settings and user name and passwords would go back to factory defaults.
1.Disconnect all cable from the back of the router.
2. Shut down your computer and the DSL box
3.Press the reset button, using a paper clip at the back of the router.Keep it pressed for 5 seconds
4. Disconnect the power cord to the router
5. Switch on the Dsl box, wait for the lights to stablize
6. Reconnect the interenet cable and the power cable to the router and power it on.
7 Let the lights stabalise on the router and power on the computer.
Check if that resolves the problem, if not we might need to update the router.
Thanks
Proton
Oct 18, 2008 | Linksys BEFW11S4 802.11b Wireless...
Disconnection of Internet
How are you connected to the internet? Is it perhaps a DSL that needs to have the PPPoE login credentials sent occasionally?
Dig into the config pages for your router and find the option for keeping the connection alive or active, that option should be near the login options for your PPPoE account.
Also consider having the router perform the login rather then your computer or the DSL itself, as most routers are better at handling the login procedure then PC's or modems.
Apr 20, 2008 | MSI Wireless-G RG54G3 Router
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
