Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Auto program TV was fine for 6 years, now it frequently displays a message prompting us to auto-program channels. Help!
  • don mc ewan Mar 21, 2008
    I cannot remove message - screen displays message to auto program channels - tried disconnecting/reconnecting to power
  • Anonymous Mar 29, 2008
    TV works sometimes but then continues to go to autoprogram
  • 129 Answers
Good day.
i would like to ask for the error message that prompts you to auto program channels.
Response is highly appreciated.
chris
Posted on Mar 24, 2008
I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
[PDF]Commercial Mode Setup Guide - LG.com
www.lg.com/.../32ld345h-commercial-mode-setup-guide....
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
How to resolve the No Signal or No Channels in Master List ...
? 2:07
https://www.youtube.com/watch?v=Tk7EUAEncsQ
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
LG TV "No program information" - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/55640-4-program-information
May 24, 2012 - 7 posts - ‎5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Jan 05, 2016 | LG Televison & Video
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Quasar model VV2008 tv/vcr
in side the mother board(kit)  there should be vertical IC gone.   check the vertical section  for  the IC number  and  replace it  ,     this  will solve ur problem
thanks
Oct 26, 2008 | Quasar VV2009 Combo
Auto program message
welcomejee said the problem is a result of dry solder on the 80 pins IC mounted at the rear side of the main board. It can be resoldered.
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Channel Reception
1) Auto-program
2) Exchange under warranty
..........T.
Dec 19, 2007 | Sansui DTV2760 27" TV
ONLY GET SAME 2 CHANNELS AFTER I MOVED.
Did you do a auto programming on it, also a $20.00 dollar anteanna would get you more channels also, go into the user menu and choose channel, choose either air or cable and do a auto programming on it, this will save all the channels that you can pull from using rabit ears
Apr 10, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
127 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
