I have a Pioneer HDTV Projection Monitor. Model # is as follows. #SD-533HD5. This was manufactured in June 2002. The middle gun is not on. This is the green gun. If I tap at the base of the gun, it will flash on, and may stay on or off. Eventually if it does come on, it will go back off and the screen turns Pink. I have been told the gun is bad? Is this true? i have been told that I could spray contact cleaner on one of the boards, and this may take care of the problem until another gun shows up. Is this true? How difficult would it be to change the gun myself?
  • Rich Hazlitt Mar 21, 2008
    It is going to be extremely hard to locate a bad solder joint. They all look good on this gun and board. Any suggestions? One more senerio. Sometimes when it is first turned on, it will work for awhile, then gun goes out and picture turns pink. Would this indicate that the bad spot is most likely on the board? Sorry, just unable to determine a bad solder joint.
  • Rich Hazlitt Mar 22, 2008
    Good call. I found the bad solder point on the bottom of the board of the gun. Now, I have soldered before, but I think this is a little more fragile than I have dealt with. How do I resolder without screwing the board up? Do I need to desolder first, then resolder? My soldering gun is fairly big, should I use something smaller?
  • 4,889 Answers
Hi Rich.. I dont think it is a fualty gun in the first place! When you tap on it, then its coming on means that there is some dry solder(loose contact). Care fully examine the circuit for any broken or loose contacts. Re-solder any weak joints and it should be up and running..
Posted on Mar 21, 2008
  • 2 more comments
  • eagle338
    eagle338 Mar 21, 2008
    Let me know if it worked..So that we can follow up on this..
  • eagle338
    If you know how to use a multimeter it would just be a piece of cake! Just take down the readings and post them here.. If you cant do this too then better take the assistance of a tech and tell him to look for a dry solder.. trust me my monitor had the same problem and the tech just put his soldering gun on one of the Ics and Its back to normal
  • eagle338
    eagle338 Mar 22, 2008
    You need not desolder the thing. But you should use a smaller soldering gun and also the smallest available soldering lead. Preferably 5.8mm or 8mm. Then carefully solder it.. Note that if it forces de-soldering feel free to do it.
  • eagle338
    eagle338 Mar 25, 2008
    Hi Rich.. whats the status?
Pioneer SD-533HD5 53 in. Rear Projection HDTV Television - Need Manual ....
ManualsLib has the manual for the SD-533HD5 here: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html . (The manual covers two models.) Once you modify the picture parameters (starting from STD, REF THEATER, GAME), these are stored as the User mode. If you press Menu when done changing the parameters, that input should maintain the User settings for the last setting until you change the Picture type. If you modified the parameters for STD and then return to that input and change the Picture to GAME, any modifications to the GAME picture parameters will become the new User Mode. See page 50 of the manual for the details: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html?page=50#manual .
I hope this helps.
May 27, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
How do i switch my sd-533hd5 to hdtv
the only way to do this is u most upgrade ur cable box to hd box then connected to a component with the color green blue and red on the back of ur tv
Nov 03, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD 533HD5 has pink screen
Sounds like the gun is trying to fire up but has internal problems. You may want to see if you want to tackle the job of changing it out. Check with MCM Electronics to see cost of a new gun. 1-800-543-4330 or www.mcmelectronics.com
Jan 17, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My pioneer model sd-533hd5 shuts off after 5 mins and goes to stand buy
Replace Both of your STKs ,if it has the STK392-110s do not go back with these they do not hold up use STK392-180s for parts call Electronix Parts 1-800-223-3205.
Dec 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
