The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps
Description
1 short beep and 1 long beep
Memory problem
2 short beeps and 1 long beep (repeats 5 times)
Unable to initialize video or video card required but not installed
3 short beeps and 1 long beep
CPU configuration error or CPU type is not compatible
The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps
Description
1 short beep
Legacy floppy drive or CD/DVD drive not detected
2 short beeps
Floppy diskette or compact disc not detected
3 short beeps
Unable to start flashing (such as when missing a utility or BIOS image)
4 short beeps
Flashing failed (checksum error, corrupted image, etc.)
5 short beeps
BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting: http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
Do this beeping code for motherboard troubleshooting.
First disconnect all memory,external video card, etc only motherboard and power supply.
Then power on if you hear continuous beeping means the motherboard working good.
Please do this beeping code troubleshooting.
No beeping meansShort, No power,
Bad CPU/MB, Loose Peripherals.
One beeping means Everything is
normal and Computer posted fine.
Two beeping means POST/CMOS Error.One Long Beep,
One Short Beep means Motherboard
Problem. One Long Beep,
Two Short Beeps means Video Problem. One Long Beep,
Three Short Beeps means Video problem. Repeated Long
Beeps means memory error. Continuous Hi-Lo
Beeps means CPU Overheating.
Memory problem
The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS :
BeepsDescription
1 short beep
2 short beeps
3 short beeps
4 short beeps
5 short beeps
Power up the pc and see if the fans are working. If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
how many times it beeps is an indication of the problem 1
short beep
Normal POST - system is ok
short beeps
POST Error - error code shown on screen
No
beep
Power supply or system board problem
Continuous
beep
Power supply, system board, or keyboard problem
Repeating
short beeps
long, 1 short beep
System board problem
long, 2 short beeps
Display adapter problem (MDA, CGA)
long, 3 short beeps
Enhanced Graphics Adapter (EGA)
long beeps
3270 keyboard cardhope this helps.
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says, there are lots of computer beeping answers out there:
1 short beep is your BIOS saying "HELLO I'M OK"
Standard Original IBM POST Error Codes
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
short beep
short beeps
No
beep
Continuous
beep
Repeating
short beeps
long, 1 short beep
long, 2 short beeps
long, 3 short beeps
long beeps
3270 keyboard card
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
No Beeps
No Power, Loose Card, or Short.
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
Repeating Short Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
One Beep, Blank or Incorrect Display
Video Display Circuitry.
Standard Original IBM POST Error Codes Code Description 1 short beep System is OK 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Display adapter problem (EGA) 3 long beeps 3270 keyboard card
