Question about Vehicle Parts & Accessories
Radar Detector in not working in New 350Z
My radar detector is going off continuously in my new car. When used in my wife car there is no problem and it works normally.
New Z is equiped with blue tooth and satilite radio and a built in garage door opener. The radar detector is an Escort 8500
If you have a heat reflective screen this will stop detector working,the way round this is to fix your detector near the front interior mirror,this is a gap and will let your detector work okay.
Posted on Oct 10, 2008
If the radar detector does not receive the appropriate voltage, constant voltage, or especially if it receives over voltage, then it may cause erratic behaviour and false alerts. Though most cars are said run at 12v, in truth the figure isn't always so exact.
I was having a similar problem when I hard-wired my Passport 7500 into my Honda. The car's voltage was just a little higher than recommended, and as a result my passport 7500 gave erratic false alerts. The main symptom was that it would suddenly display three Ka bars non-stop until I reset the detector. It would not slowly build up to the three bars, as a real approaching signal would cause, but rather it was a sudden and instantaneous three bars.
I recommend that you check the voltages in your Z. Check the voltages on where the detector is currently, then check some other areas like the cigarette lighter, maybe some accessory under the dash, etc. To be thorough you should also check the voltages in your wife's car, which I would bet reads more in-line with what's recommended by your detector's manufacturer.
Ultimately you may need to wire an appropriate resistor in-line to provide your detector with the appropriate voltage in the 350Z.
Cheers,
-William
Posted on Oct 08, 2008
It may be the Garage Door Opener....
Posted on Jun 08, 2008
It appears a different outlet-power port does not set off the radar detector. I do not know the reason for the difference but it appaears to be ok at the 2nd port. I will monitor the situation for a while
Posted on Mar 25, 2008
SOURCE:
Cobra ESD 9210 Radar Detector for sale
USD 75 is what other used ESD 9210s are current going for here.
Jul 19, 2012 | ESD 9210 Radar Detector
How does it work
Radar detectors are similar to radio receivers that are in your car or home. Radio receivers pick up signals in AM and FM frequencies. Radar detectors find the frequencies that are used by police officials using radar guns. Once the radar detector finds a frequency being directed at your car, it signals the driver somehow, most likely by beeping. It is a simple technology. Although, as law enforcement agencies expand the frequencies to detect speed, companies need to produce more radar detectors
Sep 27, 2010 | ESD 7330 Radar Detector
What does VG2 mean
It is a radar detector detector. So if you are running a radar in a state where it is illegal, this technology can detect the presence of your radar detector and you can be pulled over and ticketed. This is done by detecting the local oscillators and other "RF leakage" from the radar detector.
Sometimes you may notice that when you are near another car with a radar detector, your radar detector may go off. There are situations where your own radar detector can detect leaking RF energy from another detector in a nearby car.
Sep 09, 2009 | XRS 9330 Radar Detector
Radar detector codes
When any detector "detects" radar, it will produce some form of Audiable sound. If someone is speeding, they need to slow down IMMEDIATELY if they want to avoid a ticket. It doesnt really matter if the radar gun is x, k, ka, ku, etc. You will probably get a ticket if you dont slow down.
Most dectectors will have indicators lights or displays that indicate the x, k, ka, etc., radar signals are actually being detected. This can provide SOME useful information. THe letters simply designate BANDS of frequencies that are used to send the radar beams. It is similar to changing the channel on a radio - k and ka bands use HIGHER frequencies for their radar signals.
X band is the oldest radar band and it is used for police radars AND door openers at supermarkets and other locations. If you drive by a supermarket, your radar detector is likely to go off and it is almost certainly going to be X band. CHeck it out next time you drive by a supermarket with an automatic door opener.
Since the police and the radar companies like to play cat and mouse, newer radar bands have been invented that OBSOLETE the older radar detectors. When the K bands showed up in the police radar guns, the radar detector folks had to have a new product offering that would detect X band and K band. And the race continues to go on even today and now, there are LASER police speed detectors and the new "RADAR" detectors now need LASER detectors as well. If you want to know the exact frequencies of these "bands" (K, Ka, etc), let me know and I will send them to you. But they are operating in the tens of GigaHertz regions.
THX
r
Aug 28, 2009 | XRS 9330 Radar Detector
Cobra radar detector
Police usually do not leave their radar guns turned on all of the time. Indeed, most police officers prefer to use the "instant-on" technique to nab speeders. Instant-on works by leaving the radar gun in standby mode (no radar emissions) and then releasing a trigger button to instantly turn on the radar gun to measure a vehicle's speed.
You can check to see if your radar detector is detecting radar by putting it in Highway mode and then driving to a shopping center or other businesss location which has microwave radar automatic door openers. You should get either X band or K band alerts for these microwave automatic door openers. If you do not get any alerts for these door openers, and after having checked a few other locations which have microwave automatic door openers, then this would indicate that your radar detector is defective.
Apr 20, 2009 | XRS 9440 Radar Detector
Got this from a friend but never used one before so I don't know to much about this radar detecter could you give me some advice?
The best place online to learn about radar detectors and how to use them is radardetector.net. I would highly recommend a new radar detector model compared to any old Uniden radar detector. Uniden has been out of the radar detector business for some time now.
Apr 07, 2009 | Uniden Vehicle Parts & Accessories
Cobra XRS 9950 Radar Detector not powering up
At the end of the power cord for the radar detector the end screws off and there is a fuse for the radar detector itself. Check it....
If that isn't the problem post back for further help.
Thank you for choosing Fixya!
-dan
Mar 19, 2009 | ESD 6100 Radar Detector
Getting false alarm from laser. Laser alarm keeps
If the laser continuously falses even with the car's ignition turned off, then your radar detector has an internal electronics problem. If your radar detector frequently or nearly continuously falses for laser while you are driving even in the middle of nowhere, then most likely the cause of the problem is either poor power and ground connections or electrical noise within your vehicle's electrical system. Jump over to radardetector.net for help in resolving these issues.
Mar 15, 2009 | Passport 8500 X50 Radar Detector
I need a new speaker. Where can I get one?
I purchased one at Radio Shack for my Radar Detector.
If you take it to the store they should be able to show you one.
Best of Luck.
Nov 07, 2007 | Traveller II Radar Detector
Vehicle Parts & Accessories Logo
218 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
