Hi, I have a fujitsu siemens amilo Xi 3650 notebook, the screen went blank on it. I've since found out a need a new inverter for it. How can I find out the exact type/spec of inverter to get?
could be hard drive failure,or you might try to reinstall windows before bying a new hardrive,but before any of that go to the BIOS and make sure that the boot order is right usualy hard drive first
go to control panel then system then device manager look for you keyboard uninstall it then scan for hardware changes the machine sould detect the keybaord and install it automaticly
Try useing external monitor?
Dumb Question.
Try switch monitor button? Fn + F5 (together) usually
Hard way,
Remove hard drive, maybe even CD Reader, Floppy.
Power on system
hi i have fujitsu sieman amilo 3710 it will no switch on there nothing no noise no light but when put it on charge the little charging light comes on to say its charging can u help
need more info on exactly what happens...
do you see any lights on ..be descriptive..
do hear any beeps..can u hear anything...fans working hd clicking cd drive kicking in etc
it seems that before shutdown system was updating pc (in all cases) windows update does this in silent mode so sometimes youre not to know.
boot up as normal...wiat a minute or so ...press and hold power button until pc shuts down completly(you can hear this) a light should be lit momenterily and then fade off.
you may now be able to reboot.
hi
change place og your magnetic device nearly to display if there.
reset your monitor.
degauss it.
also check your cpu display option with other display if u have.
