RCA 52 My TV (RCA D52W27D) stoped working. The power light will blink on then off 3 times and thats all. No picture or sound at all. It was made in August of 2004. I had a repair man come over and diagnose it "$85" and he said that I had to replace the whole board $435. Then he called me back 4 days later and said I should just throw my TV away vs repairing it. It is only 3 years old, is this model that much of a lemon? Someone Please help, I cant believe I wasted $2000 on a TV for only 3 years of service. Thx, Chris
  • 2 more comments
  • Anonymous Apr 20, 2008
    I have the same problem with mine as well. When trying to cut on tv it will blink 3 times with a click noise will sound. I dont think it is a power surge because if you mess with it long enough i will cut on again, mine does anyways and works great when it is on. it can make you ill though trying to get it on.
  • Anonymous May 27, 2008
    WUZBAD,
    I have the same model # dated the same year as you. I am actively trying to fix the problem myself. I do not know what you have done, but here is where I am so far on this.
    I have logged on to RCA s web site and downloaded the user's manual, which has not been very helpful. I have looked at the FAQs at www.rca.com under service to look for advice and the only thing that I see is a bit that says to unplug the TV for ten minutes to reset it. I unplugged my set for half an hour and the problem appears to be fixed for now.
    I also saw something similar to the problem that we are having described as a possible lamp issue, but I want to call RCA and see if they have an answer for this. Although my set is working properly for the moment, it has only been a few hours.
    Note I looked up the entire service model number for my TV and it is D52W27DYX1. Does that match yours?
    RCA website describes a tag on the back right of the TV that identifies the lamp type, but I could not find this tag anywhere on my TV.
    I will post a follow up with anything I come up with.
    I do not believe that I experienced a power surge at the time when the problem began. What was your experience in that regard?
  • tktibbs Oct 19, 2008
    We have the exact same problem. Please let us know as soon as anyone has figured something else out.
  • tktibbs May 11, 2010
    We also have the same problem. No power surge or anything. One day it worked fine, the next day the power button blinks three times but never comes on.
  • 979 Answers
You may have been the victim of a "power surge", rather common in today's electronics scene. Lightning, spikes, static discharge, all can wreak havoc like this. Your set more than likely succumbed to one of these maladies...accordianman
Posted on Mar 21, 2008
Power light blinks 3 times, no picture
Thats usually caused by the cp150, CP120 or CP114 capacitor having failed. You can get the repair kit by the same name from www.tvrepairworld.com The kit contains the caps and the instructions.
Jun 03, 2010 | RCA HD52W56 52" Rear Projection HDTV
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
POWER LIGHT FLASHES 3-4 TIMES AND SOUNDS LIKE TRYING TO COME ON B
This will need a capacitor replaced on the power/deflection board. (CP150) This is a very common problem on these sets. Service man will probably charge at least $200
Jul 05, 2009 | Televison & Video
POWER WILL NOT COME ON. BLINKS 3 TIMES WHENEVER I TRY.
Look at the upper left hand corner of the main board for two bad electrolytic capacitors. They will have a bulged top if bad.
- Dan
Apr 28, 2009 | Televison & Video
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W27D The Three Blinks of Death
Check 3 capacitors on deflection board cp150,cp111,cp114 most of the time this is the problem 2200uf16v /330 uf 35v /220uf 35v.
Oct 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
