Question about Microwave Ovens
Microwave oven I wanted to use the timer feature on my microwave but accidentally used the cook mode. There was nothing in the microwave and it quit working. It didn't trip the breaker so that isn't the problem. Did I ruin the microwave and is it fixable?
  • 53 Answers
Hi pepper,
you may have damaged the transformer or magnetron or both, it is fixable, if you are in warranty contact the manufacturer, if not you should only have it repaired professionally which unfortunately may cost you more than a new microwave but you may want to have it checked anyway.
Posted on Mar 21, 2008
SOURCE:
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
My daughter wanted to run the timer on the microwave but accidentally ran the oven for 16 minutes. It overheated and blew out. Can this be repaired?
Your can be repaired, but it's generally not worth the cost. Running the oven empty usually destroys the magnetron tube which generates the microwaves. The tube is replaceable, but it's a costly part. And the repair should be done by a professional because of safety concerns. Between the cost of parts and labor, it's usually not much more (and sometimes even less!) expensive to buy a new oven.
While the kitchen timer feature of a microwave is handy, many people accidentally kill their ovens this way. You might want to pick up a small digital timer when you shop for a new oven. It's cheap insurance.
Jan 09, 2011 | KitchenAid Microwave Ovens
Microwave runs but does not heat or cook food
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber. This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load. Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try “cooking” a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
Jan 18, 2010 | LG Microwave Ovens
GE Microwave wes1384sm2ss quit cooking. it
Owners of a GE WES model might want to look at this blog post.
Nov 28, 2009 | GE JE1640 Microwave Oven
Unit is dead after accidentally running it empty.
If you ran it for that long with nothing inside, there is a good chance it self cooked.
It can probably be repaired. The economics of the repair is something you will have to judge for yourself.
To assist you, may i suggest you visit www.repairclinic.com and check on some major parts for your make and model. If the parts = more than 25% of replacement, I think id be moving on. Expect to pay a pro at least $100.00/hr labor. You should NOT do it unless you are skilled at handling delicate and lethal electronics. A microwave can kill. Another thing, after you fix it, you have a lot of $ invested and still have a old machine that ran for 13 + minutes empty.
Oct 13, 2009 | Microwave Ovens
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
Microwave light and timer work, but no cooking
IF IT TURNS ON AND SOUNDS LIKE ITS COOKING IT IS PROBABLY THE HEART OF THE MICROWAVE THE RADIATION PART WENT OUT IT IS MORE RECOMENDABLE TO REPLACE THE WHOLE MOCROWAVE
Oct 03, 2008 | GE JVM1850 1000 Watts Microwave Oven
We have this old Radarange Amana MICROWAVE from the 70's and dont quite know how to use it.
Normally the dials are the timer for cooking time plus cooking power level dial, for defrost, medium, high, etc.
It may also have a start button to start it cooking. If not, then you place the food inside, shut the door, then rotate the timer dial to however many minutes you want.
If this does not answer your question, maybe you can take a photo of the controller and post it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Amana Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
