Question about Hitachi 43UWX10B 43" Rear Projection Television
Convergance issues and possible suspect resistor
Hello I am having problems with the white green and pink or red not lining up properly. I opened the back and found a resistor rk58 that measures .5214 Mega Ohms. The resistor is discolored so I can not tell the rating of it. I would also need to know the ratings of the other associated resistors. Any help would be great.
  • yankees1 Mar 21, 2008
    I already tried that. Like I said reisitor rk58 is reading .5124 Mega Ohms so I would imagine it is a resistor problem and possibly an ICS Chip trouble
  • yankees1 Apr 10, 2008
    I ordered the service manual online. I replaced the rk58 3.9 ohm resistor and the IC chips, part number cz01341. Turned the TV on did an auto adjustment and the TV is fine. Thanks for the input.
  • 871 Answers
To play safe. replace that resistor.
about your convergence problem, All the available geometry and grayscale tracking adjustments are done by manual controls located inside the set. They may be labelled. A service manual is required to make any adjustment.
SERVICE MODE WARNING:
Without proper documentation and training, you can probably do quite a good job of messing up your television set, perhaps even damaging it.
Don't mess around with the service mode adjustments unless you know what you're doing and have the service manual to guide you.
Once you enter service mode the first thing you should do is record all the original values BEFORE you change anything! - This is the only way to restore the television to its original (factory default) state should it become necessary to do so.
Posted on Mar 25, 2008
  • earl norman llanera
    earl norman llanera Apr 10, 2008
    well thats good to hear, in any situation, if you think i had assisted you in any way, please rate my solution. thanks a bunch!
    Genius:
  • 1,665 Answers
You need a service manual give make and model to look for
    Genius:
  • 3,587 Answers
Reading a resistor 'in circuit' will almost always affect it's ohmic ratings. And you say it's discolored? Sure sign of either aging from heat or excess current.
do you plan on doing the repairs yourself?
    Guru:
  • 731 Answers
Try the changing the Cable.This has fixed many convergence problem.
Regards.
Riz
Posted on Mar 21, 2008
When lining up convergance, green lines up in the center, red lines up perfectly with that but the blue is way off. on the single cross and even more off on the multiple cross but mostly on just the right...
hello the problem is down to the convergance ic, there are 2 big black chip that sit on metal frame called a heatsink they are usually located behind the tuner board on the right side of the tv,stk-110 may be the part number, also in front of the ic are some resistors and 2 capacitor at either end these will need to be tested ,
you have to desolder 1 end of the resistor so you get a proper reading on the mulitmeter, it's lot of work but if you can do it yourself it would cost about 40 to 60 pound good luck
regards
shaun
Sep 09, 2010 | Panasonic Televison & Video
Every thing looks doubled
On board above your Chassis it has a regulator IC
STK730-010? replace it! Call Mats Electronics 1-800-628-1118
Jan 06, 2010 | RCA P52926 52" Rear Projection Television
Pink and green lines around images on the screen
Your convergence ic's are bad along with bias resistors.
Oct 24, 2009 | Philips Magnavox 51MP392H Rear Projection...
Replacement power board
NEXT TO THE FLY BACK THERE ARE THREE, (CMT) FUSES THE CENTER ONE IS MORE THAN OPEN. THEY DON'T LOOK LIKE GLASS FUSES, THEY LOOK LIKE CM RESISTOR/CAP LIKE ITEMS. GOOD LUCK.
Feb 20, 2009 | RCA P52926 52" Rear Projection Television
Samsung SP42W4PHX convergance problem
Hi
The resistors are 39 ohms, metal oxide.
Usually both the stk392-010 ic`s (on heatsinks )
want swapping. You can get them off ebay..
Dave H.
Jan 17, 2009 | Toshiba 53H71 53 in. Rear Projection...
Wavy Red lines
hi there,
if you are familiar with electronics you can do this :adjust voltage at hight voltage block it has screen and focus written on it and comes from flyback transformer,but be careful cause it can be to dangerous if you touch something else,ah,ah adjust only the one that says screen and has a R on top,that means red,ok,thanks.
Jun 19, 2008 | JVC AV-48WP30 48" Rear Projection...
I hit the accept key without resolution after paying for online assistance
Hi
>>Does the chip STK392-120, looks burned.
if yes, replace it.That will fix the problem.
>>There are two IC's, a 392-150 will be the best replacement, and if there are any large burned resistors on that board (should be pretty obvious), then they need to be replaced, too. If there are , let me know the board designator number (it will be "RK-XXX")
Thanks
Riz
Mar 21, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Problems with convergance and possible blown resistors
your convegence amp ic 's are faulty,that resistor is possibly opened under load from the faulty ic's.
Convergence 3D
You have to try auto convergance from the menu.
There ust be convergance adjustment on menu.You will find cross at center of the screen.green cross is the refrance ,you have to overlap red and blue to form white cross.
once you have formed white cross than the picture will be perfect.
Jan 09, 2008 | Zenith R56W36 56" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
