Question about Vtech IP 811 Cordless Phone
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
  • 19,396 Answers
The mac ID is a unique identification code assigned to each network communication device by an international authority. Not even factories can use the mac address as they like, the have them assigned in range. the only way to change the mac address is changing the device itsef (phone), as mac address is being assigned to each device even before it has been built. I don't think there is any way yopu can use the phone on a different base, unless you find a way to reprogram base/phone firmware as you like.
regards
Posted on Mar 21, 2008
  • Ginko
    Ginko Mar 21, 2008
    What you can change is the base ID, to register a compatible handset, but I think you need a 8100-2 base to register your 8100-2 handset. To change base Id check all other posts, and remember to accept best solution among them.
    regards
  • 4,889 Answers
The base station of both models is the same and can be registered with one another.. checkout this manual
If it still doesn't work get a replacement as the one you have bought may be faulty
  • eagle338
    eagle338 Mar 21, 2008
    Dear technotop.. i didnt copy your thing.. i just googleD for this manual..since its the support site thats where you will find it..
  • eagle338
    eagle338 Mar 22, 2008
    Did you figure it out?
    Scholar:
  • 105 Answers
The manual is: here
instructions on how to register handsets iare on page 7
Please rate the assistance given accordint to its merit - I hope this is useful. Regards Dave
  • Anonymous Mar 21, 2008
    how can so many contributors profit from just copying information - not very polite eagle 338!
  • 97 Answers
It should be that you simply enter the base ID (the number on the bottom of the base) to register the handset and use it.
Power off base unit,Press and hold SEL on the handset,Enter a new BASE ID once the prompt appears on the handset,Press SEL to save it.
Thanks.
    Genius:
  • 3,422 Answers
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
6ya staff
SOURCE:
Is it possible to change the Panasonic KX-TG6541 hand set numbers ? speaker stopped working so I want to change handset #1 to Handset #4 & Handset #4 to Handset #1
yes de-register most of the phones from the base station and then
re gister them in the correct order to get the desired numbers. You have the instruction manual from my earlier post so just de register most of the phones being 2 to 4 and re resister them in the desired order .
Dec 20, 2014 | Panasonic Lands Phones
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 25, 2011 | AT&T E5640 Phone
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Can't register new handsets
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
You can register additional handsets to have up to five handsets per base unit,
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING.
If the handset registration is successful, you will hear a confirmation tone and
the <antenna icon> will stop flashing.
The handset will automatically be allocated the next available handset number.
This handset number is shown in the handset display in standby mode. If the
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Apr 10, 2009 | Lands Phones
BT Diverse Classic 3000 Telephone Handset Registration
To register new handset:
AT THE BASE STATION
1. press and hold down the PAGE button for about 10 seconds until you hear a tone
AT THE HANDSET:
1. press the SET button
2. press the INT button
3. press the * button - the base station numbers should now be displayed (1, 2, 3, 4 )
4. enter the number of the base station you want to register to
5. press the OK button, it's got two arrows on it, and enter the base station 4-digit pin number (Unless you changed this at some point it should be 0000), and press the OK button again
Jan 04, 2008 | Lands Phones
Cannot register handsets
I was having the same problem, and ended up putting each handset in the main base station to register.
Nov 11, 2007 | Uniden TRU8885-2 Cordless Phone
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Registering a new phone
With a little searching I was not able to confirm this phone could handle more than one cordless handset. Are you replacing a defective handset or trying to add a second. If adding, do you know if it can handle the second unit (is it advertised on the box, in the user guide, etc?) If replacing, you most likely have to de-register the old handset on the base unit before you can register a new one. If you are adding, try de-registering the working handset anyway and registering the new one. If the new one registers and you cannot re-register the once working phone you will know either the system cannot handle two phones or (if the new one will not register but you can again re-register the original) that the new handset has a problem and should be returned.
Jul 10, 2007 | Uniden Cordless Phone
Open Questions:
See all Vtech IP 811 Cordless Phone Questions
Vtech IP 811 Cordless Phone Logo
1,305 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Ekse
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
