Panasonic television when i turn my television on it is good, but after 5 - 10 minutes it starts to go dark until it is almost black. What would cause this
  • 50 Answers
MAY HAVE A BAD CONNECTION --THERE IS A FILIMENT VOLTAGE THAT LIGHTS THE PICTURE TUBE THAT IS GENERATED FROM THE HIGH VOLTAGE TRANSFORMER--SOMETIMES THE CONNECTION BREAKS ,,,SO THE TUBE STARTS GOING DARK (SLOWLY) TECH COULD RESOLDER CHEAP!!!
Posted on Mar 22, 2008
Screen loses brightness at irregular intervals, then eventually returns to normal brightness.
Shut off the whole TV including the cable and the wires. Wait for about an hour and then turn it back on!
Dec 10, 2011 | LG 32LG30 32 in. LCD HDTV
We have a Polaroid FLM-323B. Have issues starting
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
I would suggest not to try to use the TV until the problem is solved becuase more damages can result.
Please post back what you find.
Nov 16, 2009 | Polaroid FLM-3232 Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Chage bulb tv is still dark
The wrong or faulty lamp may cause darkness
Apr 21, 2009 | Panasonic PT-52LCX66 Projection Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Dark fuzzy picture when tv is first turned on
I am having a similar issue. Did you ever figure out the problem??
Feb 29, 2008 | Televison & Video
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
Dark picture
I think you have a regulation problem and all the voltage supplies are lower than what they should be,the fact that the picture gets distorted is one thing it lead me to believe that is the problem.This can be caused by a loose conection in the power supply ,I would suggest not to use it until it gets repaired or it might become worst and more expensive.Be careful if you remove the back and try to repair it yourself.
Oct 02, 2006 | Panasonic PT-61G54 61" Rear Projection...
PICTURE DARK
I had the same problem soI decided to go ask at our local tv shop Panasonic warranty place and he was nice enough to tell me the problem . So for everyone reading .. these had a defect with some of the disc capacitors they used on the CRT board it as 2 on there . The second problem is with the ``YC`` chip . panasonic sets have many unusuall malfunctions caused by this chip such as a black & white picture or brightness problems . unfortunatly my set has a bad chip . There we all learned something today . he invites you to contact a Panasonic ``rep`` he will tell you the same thing .
Nov 15, 2005 | Panasonic PT-51G44 51" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
