Question about Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Automatic pump for 10 gal shop vac
How do i set up the hose for the pump to work? I have water in my basement and the tank fills up way too fast. HELP!
    President:
  • 1,314 Answers
First you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Posted on Mar 21, 2008
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
Shop vac is not pumping out water just fills the canister
The question makes perfect sense assuming we are talking about the ShopVacPumpVac. These devices are, essentially, a combination shop vac and sump pump. For those answering the question, you can see literature on these vacuum/sumps here: https://www.shopvac.com/includes/streamPDF.asp?loc=pdf&id=Shop-Vac-Pump-It-Out .
When I have experienced the loss of drainage, I have found a couple obvious problems and solutions.
First, make sure that the garden/discharge hose is not kinked at any point along the line from the vacuum to the outside. If kinked, the line will not drain.
Second, the baffle can become blocked or clogged. Take the following steps to determine if your baffle is clogged and to clear the clog:
1. Turn off and unplug the vacuum.
2. Unclip the two lid clips.
3. Lift the lid of the vacuum. When properly set up, the baffle hangs below the filter housing on an opaque hose about 1 foot in length.
4. Grasp that hose and pull firmly downward. Once removed, I take that hose and the attached baffle to an outside garden hose.
5. Pull the baffle off the opaque hose.
6. Spray water from your garden hose through the opaque hose to make sure it is clear.
7. Spray the baffle clear.
8. Lightly tap the port of the baffle, where the opaque hose has been inserted. Most of my clogs have been the result of hair balls (or worse) at this point. Just tap any blockage out and rinse.
Third, reattach the baffle to the opaque hose. Reattach the opaque hose and baffle to the motor under the filter housing. Set the vacuum top on the canister. Click the locking clamps closed.
If this doesn't result in clearing the clog and allowing it to drain, then you are in the exact spot I am right now. If I figure out this new problem, I will update further. But I have cleared this kind of clog maybe five times in the six months I've been using this new Shop Vac Sump Vac
Sep 08, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
My basement is flooding and my 5 gal shop will not **** up the water. It works momentarily and then spits the water back out
You should remove the filter that is inside the vac. This should allow for the vac to **** up the water. But just in case that doesn't do it, here is a link to a site that may contain a free download of your manual:
www.shopvac.com/parts_pdfs.asp?p=%25&Submit=Search
Just look up your type of vac and click on it.
Good Luck!
Jim
Oct 01, 2010 | Shop Vac (464-38-10) Canister Wet/Dry...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Dec 22, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Dirty water blowing out of hole in top of unit... help!!!
perhaps your husband took the water stop(float) ball out of it . that stops the unit from over filling with water .
Mar 09, 2017 | Shop Vac 401-04-62 Original Wet/Dry Vacuum
Set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Craftsman 20 Gal Wet/Dry Vacuum model number 17762
you did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
Feb 13, 2008 | Craftsman 17762 Wet/Dry Vacuum
Shop Vac 584-06-00 Canister Wet/Dry Vacuum Logo
572 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
