Question about ASUS A7V400-MX Motherboard
Boot problems will not deteck hard drive on startup but will detect cdrom device have tried to new drives with the same problem
  • 53 Answers
U didn't mentioned the harddisk capacity.
See the motherboard manual for hard disk  support
Pl try it
Thanks
Was this soultion useful ? show ur appericiation for it
Posted on Mar 21, 2008
My hardisck no deteck in my PC
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 09, 2013 | Seagate Barracuda 7200.12 500 GB 7200RPM...
At the startup menu i am getting a message that says, Reboot and Select Proper Boot Device or Insert Boot Media in selected Boot device."
Firt thing you can check is wthr your harddrive is detected or not. to do that you have to enter to the BIOS,To Enter BIOS you have to press DELET or F1 or F2 key(Mostly DELET). Now inside the BIOS in main menu check if your hard drive is showing or not. If it is showing there then you try to find out boot sequence, option after getting the boot sequence optuon check if the first device is other then hard drive.
if your harddrive is detected and your first boot device is also set to HARD drive then it might that your Operating system is Crash, in that case you need to re install the OS.
Now if you can see your hardrive in your BIOS then you can open the case( remember to unplug all the cable, Power, VGA, KEYboar ...etc) and try to inter change the harddrive cable connting cable, i mean just try to chage the port of the cable to other one and try switch on your computer ... if still you find the same problem then try changing new cable. ....well if still you have the same problem then i am afraid that you might need to replace the hard drive with new one.
Sorry for the Bad Englsih. Hope the above steps will work for you and you understood what i tried to say.
Cheers:)
Jul 25, 2012 | Gateway DX4300-03 Desktop PC
My laptop crashed and we installed a new hard drive, as HP said, but we received a message that it did not recognize operating system. So we ordered recovery disks and put those in turned it on, still no...
ok, First you should understand the new hard drive is empty, it is not even formatted. At this point the most likely issue is the bios not recognizing the Hard Drive because the Bios is not set to automatically detect the hard drive. Enter the Bios and go to the hard Drive selection sub menu and have the computer automatically detect the hard drive size and type. Then go to the boot sequence menu and alter the boot order to CDROM, Floppy (If you have one), Hard Drive, Network. Reboot the computer and you should see the RAM test, hard Drive Identification and then the CDROM should start to boot. I can't be more specific about the steps because your post didn't include the model of the laptop. All of this assumes your CDROM is still in working order since HP laptops have a known issue with CDROM's going out for no reason. The hard way for dealing with this would be to get an encloser to put a hard drive in to make it portable and connect to another computer and do the partitioning and formatting of that new drive on the other computer and solve the problem that way.
Feb 16, 2011 | HP Computers & Internet
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
When I turn on my acer aspire one d250 it says Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
6. USB CDROM
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Jan 03, 2011 | Acer Aspire One D250 (99802378332) Netbook
G60-230US PC Notebook died. It reads: "No bootable device--insert boot disk and press any key" on startup. startup test failed: "there is no hard disk."
It means that your notebook is not able to detect any hard drives or a bootable drive
also plz check if there are any cd/dvd or any external devices like flash drives or external hard drives connected to the nb.. If so disconnect all the external devices and try to boot up ..
If it does'nt work go to the bios screen by continiously tapping F10 or F2 or DEL key as soon as you turn on the nb and check if the hard drive is detected or not.. if its not reset the hard drive and retry.. If the hard drive is detected run a hard drive self test if it fails.. replace the drive if it passes run system recovery
Hope it works
All the best !!!
May 06, 2010 | HP G60-230US Notebook
Dell Optiplex GX270 will not boot from disk
Does it show
boot from cdrom?
did you answer (Y)
then hit spacebar?
have the bios set to boot from cdrom/first boot device cd-rom?
If any of these settings are not applyed you will not restore xp on your computer
go into bios and conferm settings
first boot device if set as floppy or hard drive change to cdrom
on some systems you can hit the (f12) key to bring up a boot window and select the cdrom and boot from there then it will ask the normal questions
Dec 03, 2009 | Dell Optiplex GX270
Pc will not boot, it can not see hard drive. tried new hard drive but no good. The hard drive works in other computer. the hard drive can not be detected in BIOS.
Try switching the eide ribbons from the CDrom to the hard drive. Sometimes, the computer tries to read the cdrom as the primary and the hard drive as the slave. I generally just leave the CDrom out, place the hard drive in with ribbon and let it register in bios.
Oct 04, 2009 | ASUS A8N-E Motherboard
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Cd rw/dvd rw now working
If you know how to open your laptop, you can try seeing if the cable to the CDROM is connected properly. On startup, does your computer recognize the drive? If it's not the cable, you need a new cdrom drive.
Jan 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
ASUS A7V400-MX Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
