Not enough information to answer with any sense of accuracy, so let's just take a stab in the dark that is it a computer you are asking about and not a tire balancer or a smart fridge :>D
https://community.acer.com > Displays > Monitors
Sep. 4, 2018 - The "Auto Config Please Wait" error tends to pop up when full screen games are being played. To get around this error, change the settings ...
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment
Probable Cause
The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
Configure the console for the proper machine type by pressing Level UP, 80, ENTER
Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
Once the proper machine type is shown on the display select the machine type by pressing ENTER
This completes the steps necessary when your Stairmasterdisplay readsCONFIG RQRD or NTM CONFIG RQD
This error indicates a corrupt registry. Luckily, when Windows is installed, a pristine copy of the registry hives is also installed and it remains untouched...replacing your corrupt registry hives with these ones will allow you to boot your operating system again. You may have to reinstall a few programs and drivers but all of your data will remain intact and you really won't lose anything. I will describe the process to you. I will also include instructions on how to back up the current registry in case you want to go back to it for any reason.
First you will need to locate the Windows install disc. If you don't have one you can borrow one as you will not need a key to perform the steps.
Put in the disc and perform the steps necessary to get your computer to boot to it.
Once you are the "Welcome to Setup" screen, press R to go into the Recovery Console.
Enter the administrator password when prompted
Tell the program what installation of Windows you would like to recover.
Now for the commands
md tmp (this creates a directory labeled tmp)
These 5 commands will make a copy of your current registry hives and back them up to the tmp directory. Type these in first. ENSURE you back them all up.
Once you have entered your last command type exit to leave the recovery console and your computer should restart.
If you want to put the old registry back for any reason, simply follow the same steps but instead delete the current registry and replace it with the files that you placed in the tmp directory. Ensure that you remove the .bak extension from the file when you copy them over.
Really, other than this, the only other known working option is to reformat your computer.
Probable Cause
Corrective Action
Insert the Windows XP startup disk into the floppy disk
drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart
the computer. Click to select any options that are required to start the
computer from the CD-ROM drive if you are prompted to do so.
When the "Welcome to Setup" screen appears, press R to
start the Recovery Console.
If you have a dual-boot or multiple-boot computer, select
the installation that you want to access from the Recovery Console.
When you are prompted to do so, type the Administrator
password. If the administrator password is blank, just press ENTER.
At the Recovery Console command prompt, type the following
lines, pressing ENTER after you type each line:
md tmp copy c:\windows\system32\config\system c:\windows\tmp\system.bak copy c:\windows\system32\config\software c:\windows\tmp\software.bak copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak copy c:\windows\system32\config\security c:\windows\tmp\security.bak copy c:\windows\system32\config\default c:\windows\tmp\default.bak
Type exit to quit Recovery Console.
Your computer will restart.
Note This procedure assumes that Windows XP is installed to the
C:\Windows folder. Make sure to change C:\Windows to the appropriate
windows_folder if it is a different
location.
If you need more help come back.Post /
thumbs / testimonial arewelcome!
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair. missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Have you tried using the monitors menu to move the screen manually. Exit, then turn the monitor off. When you turn it back on the picture should be where you left it.
