Question about Philips 37PF9975 37 in. HD-Ready Plasma Television
Cant get cable to work
Cant get this tv to go on cable with the box
    Sergeant:
    Champion:
  • 231 Answers
What input are you using on tv from box?
Posted on Jun 23, 2008
SOURCE:
WHY CANT I GET HD CHANNELS ON MY ELEMENT ELECTRONICS 32 IN HD TV
To get HD channels you need to have a cable/satellite box that can receive HD channels AND you have to connect that box to the TV with either an HDMI cable or component jacks. A normal cable/satellite box won't work; neither will a coax antenna cable or consolidated video (yellow RCA) plug. Hope this helps!
May 20, 2014 | Element Electronics FLX3220F 32 in. LCD TV
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
I cant get cable to work viore
First make sure cable works on another set at this input where tv is, then make sure you are on cable through your menu and then scan. If you are going through a cable box then put tv on 3 or 4 and program box
Dec 27, 2010 | Televison & Video
Cant see picture on my tv screen on cable mode vcr ok
its usually your cable box or sat box. reset by unplugging box let sit for 10 min.
Jun 04, 2009 | Televison & Video
Cant wire theatre system right,only get surr. on dvd
Do you have a High Def cable box and Tv? if so you would use and HDMI cable from your cable box to your tv, then run an optical audio or coax audio from your cable box to your surrond system. Depends on which plug you have on both for the audio portion.If you dont have HD tv than you would run cable wire from cable box to tv then run red and white audio from cable box to surround system, to listen to it you would select aux channel.
Hope this Helps.
May 01, 2009 | Audio Players & Recorders
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
How do you connect it?cable box to tv with coaxial cable?composite video cable?component video cable?HDMI cable? is it a HD cable box?
solutiondoct
Nov 12, 2008 | Philips Televison & Video
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
Cant set up anyhting to my cable box/ dvdr /tv
buy a new rca cable or RF cable for you're cable box ,then connect the output of dvd red/white/yellow to the tv video input red/white/ yellow and for you're cable box connect the RF cable to tv ant.
Mar 23, 2008 | Cyberhome DVR 1600 DVD Recorder
Philips 37PF9975 37 in. HD-Ready Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
