Peavey Speaker repair
Looking for a peavey part. Where can I get it? QFM-118. The one I have is cracked.
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi, Peavey parts are pretty available, where in the world are you and I can steer you to an agent
    regards
    Graeme
  • 1,512 Answers
Hi there, didnt hear back from you, but here is a link to get you there anyways.
regards
Graeme
Posted on Apr 01, 2008
Can you repair a tear in a peavey guitar amp and will it affect the sound
I have to assume you're really meaning a tear in the speaker cone. If so, yes you can repair it if it's small and yes, it will affect the sound. Peavey Bandit amps have come with a few different speakers over the life of the name, but all will still be available either online or directly from Peavey's parts department. Here's the link-
http://www.peavey.com/support/contactinfo
Oct 21, 2015 | Peavey Bandit 112 80W, 12" TransTube Combo...
Peavey problems
cracked solder joints, how old is it, they have 5 year warranties..
Aug 02, 2014 | Peavey ValveKing 100w All Tube 212 Combo...
Replaceing subwoofer which is the hot wire
the red or white one, and polarity of the speaker is red+ black - if it is a black widow, The stamped steel peavey has the + - sign stamped into the terminal pad. you can always trace the hot wire as the one that connects to the tip of the 1/4 inch input or pin one of the speakon 4 connector. This works on any speaker.
Mar 21, 2014 | Peavey Pv 118 Pv118 Single 18" Subwoofer...
My peavy 118 subs dont play as loud anymore what could be the problem.
Circuit resistance from corrosion, or broken strands int he flex wire connections between voice coil and the terminals. It is also possible the voice coil form is distorted. It is also possible a capacitor in the amplifier is in the early stages of failure.
Jun 11, 2012 | Peavey Pv118 1x18" Subwoofer Speaker...
I have a Peavey 118 Subwoofer and was wondering why it isn't working... I have another one exactly the same so I am sure it has something to do with the sub... I took a look inside and everything seems...
Test the resistance of the speaker with wires disconnected. If it doesn't show around 8 ohms plus or minus 2 ohms, it is probably blown requiring either re-coning or replacement.
Jun 17, 2011 | Peavey PV 118 Speaker PA Sub
My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
Looking for replacement components for my peavey speakers 2 x 15 inch 2 x tweeters 2 x crossovers 2 x horns all above for 15 inch peavey eurosys 4 product 15005760 2 x 12 inch 2 x...
Fixya doesn't do prices or delivery. We only supply information. See the link for spares suppliers including Peavey themselves.
Peavey Replacement Repair Parts, Speakers, and Accessories
https://www.simplyspeakers.com/peavey-speaker-repair-parts.html
Factory replacement Peavey speaker parts, diaphragms, replacement baskets. ... Peavey 1208-8 SPS BWX Factory Speaker Basket, 12" Black Widow, 8 Ohm, 00560770. Peavey SP-15825 Factory Speaker Basket, 15" Scorpion, 8 Ohm, 00015040.
Peavey - Replacement Speakers, Raw Drivers ... - Parts Express
https://www.parts-express.com/brand/peavey/339 Results 1 - 16 of 323 - Welcome to the Peavey Store at Parts Express. Peavey was founded in 1965 and is now one of the best known names in professional audio. With innovative products such as their field replacement baskets, powerful amplifiers and PA speakers they have become a mainstay of musicians around the ...
Speaker Components - Peavey.com
https://peavey.com > Support From the Low Rider™ sub woofers, with incredible power handling capacity and impressive bass response to the steadfast Black Widow® and BWX™ speakers with replacement basket assemblies, the Peavey line of speaker components is consistent and innovative. Think it might be difficult to make up your mind what ...
peavey speaker spares Google Search
Dec 23, 2017 | Audio Players & Recorders
I have one Peavey SP5 that suddenyl lost the Woofer end. Horn still spits out but absolutly NOTHING at all from the Bottom 13". I swapped out fuses adn same problem, I switched outputs on the amp, same...
If you have a pair, swap the woofers. If the other one works in the cabinet, then it's definitely the speaker. If it doesn't, then you've likely got a problem with the crossover inside the unit. I believe you can get a replacement crossover from Peavey. If it's the speaker, google speaker re-coning in your area, as it's cheaper to re-cone the speaker than replace it.
Jun 07, 2009 | Peavey CH1 Speaker
Have a peavey-xr-600b peavey mixer amp. i get aloud hum and noise and cracking when plugging speaker jacks.
Hi chillin884
Not a good sign. Something has gone wrong with the output stages of your Peavey. It is not a good idea to continue plugging it in as damage may occur to your speakers. I suggest you take it to a decent music gear repair guy for a look see and give you a quote to repair These heads, like all Peavey gear, are pretty solid and worth repair. Sorry to be the bearer of bad news like this, good luck
regards
Graeme
Jul 15, 2008 | Audio Players & Recorders
409 people viewed this question
 Grubhead
Grubhead
