Question about Vacuums
Where is the reset button on the electolux 2100
  • Anonymous May 17, 2008
    I have a clarke Filtravac 14 ser# 004124 mod 2380001 I have no power i've checked all the switches and made sure the bag is in correct but still no power is there a reset switch?
  • Anonymous Jan 15, 2009
    N137 Power nozzle just stopped working. Pressed the reset button and still does not work, any ideas?
  • 126 Answers
There is no reset button on the 2100. If it shuts down, the indicator lights will tell you why. If it has been overheated, there is a self-resetting switch which will shut the motor down and the light will come on to indicate that particular problem. When you turn the machine off and then back on, it should re-start provided you have given the motor ample time to cool down. This will not solve the problem as to why it overheated in the first place. There are also lights and auto-switches that will control full bag and no bag. The machine will not run with no bag and a full bag will cause it to run for a few seconds and shut off.
Posted on Mar 21, 2008
Electolux hoover 1600w power plus wont start
John, first off, you have a Hoover upright vac, not an Electrolux. If it won't start, check cord to be sure it's plugged in properly to a live socket, then find and push reset button, frequently found near the corner on the rear of the base. (Small red circle). If that fails,. then you need to take it to the nearest repair shop for diagnosis.
Nov 02, 2013 | Hoover Platinum Collection Upright Vacuum
I need a owners manuel for a electolux discovery II vaccum
mcdevito75 here, You can try online at electrlux.com
Jul 21, 2010 | Electrolux Vacuums
The telescopic wand on my electolux oxygen is stuck. Any ideas how to fix or trouble shoot this?
Believe it or not, dish soap and water can usually free that up. the other cure is silicone spray and heat.
Mar 13, 2010 | Electrolux EL7055A Bagless Canister Vacuum
I need to get the manual online please for the Electolux Envirosteamer
You can get the owner manual for 370A here:
http://www.eureka.com/service/manuals/70888.pdf
Oct 19, 2009 | Electrolux Envirosteamer 370A Canister...
I have an older electolux vacuum. It says Epic
Vacuum either has a clog or full bag that is overheating the vacuum causing the thermal switch to shut it down.
Hope this helps.
Aug 14, 2009 | Electrolux Vacuums
Electrolux model 2100
The power nozzle is equipped with a automatic shut off if something gets jammed inside it. Try resetting the button on top of the power nozzle after making sure the brush still rotates freely. A broken drive belt may also be the problem. You'll need to open up the power nozzle to check the belt. Pay attention to the screws as you take them out. One of them is shorter and is made to go into a specific slot.
Jul 27, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 2100 canister vacuum
Open the door to remove the bag. Pull the side bumpers forward when the door is open. The profile of the edge of the top and the bottom of the vacum body is a "L" shape. The cross section of the bumper is a "I" and that holds the body together. Carefully lift up the top just a little to free the plastic end cap that conceals the cord spool. There are two plastic pins on the top and bottom that hold this piece on and they frequently get broken. (If that happens repair shops drill and hole and insert a screw.)
There is a plastic protector plate that lifts up on either end and then is slid about 1/8th inch clockwise and then up.
Copy the wiring pattern on the four male connectors on the motor and the wire spool.
Post your wiring diagram and it will solve a lot of people's problem trying to reassemble this machine's -- including mine.
Oct 07, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
901 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
