Question about Sony STR-DE635 Receiver
Sony STR-DE635 Receiver-no sound at all
When i turn on my Sony STR-DE635 Receiver and either plug in speakers or headphones i get no sound. if i turn the volume all the way up and and amplify that sound (from either the head phone jack or the speaker terminals) with a working amplifier (volume cranked all the way up) i get some weak sound.any help would be greatly appreciated.
  • Anonymous Mar 21, 2008
    tape monitor button?
    i only have a tape button on the front and theres a monitor jack on the back.
  • Anonymous Mar 28, 2014
    need help. how to do or make so that from front speakers and surround speakers sound are coming together
    Problem Solver:
  • 9 Answers
Turn your volume down,press the tape monitor button.then turn up?
Posted on Mar 21, 2008
SOURCE:
No output to speekers Sony STR-DE825
Check that the mute is not on.If a headphone is plugged into the receiver the speakers will be muted.Verify the the output selector is set to the correct source.Here is a simple check.Select a strong FM radio station.Plug in a headphone.If you are receiving an audio thru the headset.Then disconnect the headset and see if the audio is transmitted to the speakers.If you still have no speaker sound check to see if the speakers have fuses which may be blown.I would try another set of speakers to determine if it's the amplifer or the speakers.The amplifer has fuses as well. Wiilbe inside if not at the rear
Oct 21, 2012 | Sony STR-DE825 Receiver
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
Have a Sony STR-DE635 that keeps blowing the 2 8 amp fuses in the power supply. disconnected all speakers and powered up with same result. Checked bridge rectifier and (2) 10000 uf caps all are good
Have you checked the rails to ground for shorts. Get hold of a variac as it does make things a lot easier.
Sound like you might have some shorted output devices.
Hope this helps
Thanks for using FixYa
Aug 18, 2010 | Sony STR-DE835 Receiver
Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
May 21, 2010 | Sony STR-DE675 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Receiver clicks and rear speakers stop working
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
Dec 09, 2008 | Sony STR-DE635 Receiver
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
703 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
