Question about Brother MFC 9700 All-In-One Laser Printer
Machine error 71
My machine is not working and displays "MACHINE ERROR 71, TURN MACHINE OFF AND CALL BROTHER. We called brother and told us to take it to a repair center. They want $200 to fix it. I can buy a new machine for $400 and it includes a new toner. Looking for cheap fix.
  • 1 more comment
  • timinator Apr 03, 2008
    Hi, I'm getting the same error on a Brother MFC 8500. I fully inspected for paper jams and found nothing. Machine is approx 5 years old and does not get hammered too bad. Help?
  • eedtown May 15, 2008
    machine gives machine error 71 all the time. I cannot use it for any purpose.
  • Anonymous Jan 27, 2009
    same :( need help if some one have a solution
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Posted on Apr 12, 2008
What is machine error 71 How to fix it?
Error 71 on a MFC-9600 means there is a problem with the motor inside the printer.
You can try unplugging and waiting a few minutes, then plugging back in again.
If it is still coming up with the error, if its still under warranty Brother will replace/repair it for you, otherwise you will have to pay Brother for the repair cost.
Mar 05, 2011 | Brother MFC 9600 All-In-One Laser Printer
SCREEN READS ERROR 71 CALL BROTHER, WHAT IS THE PROBLEM, WHAT NUMBER DO I CALL
This error means that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
If the error comes back, call Brother support, here are contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Jan 12, 2011 | Brother MFC 8500 All-In-One Laser Printer
What does Print unable 71 mean and what do I have to do to correct the problem?
Error code 71
Print Unable 71
Turn the power off and then back on again.
Polygon motor failure
Jan 03, 2011 | Brother MFC-9840CDW Laser Printer
Error 71 / It is not working.
This error indicates that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
901-379-1215 (fax)
Nov 22, 2010 | Brother DCP 1400 All-In-One Laser Printer
Machine error 71
901-379-1215 (fax)
Nov 15, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 appear machine error 71? why?
The error 71 indicates to "Unplug unit, and call Brother" after calling Brother they will refer you to an authorized dealer for repair which costs more than a brand new unit.
please rate !
Apr 11, 2010 | Brother IntelliFAX 4100 Laser Fax
GOT ERROR 71 PLEASE HELP
any of the error 7X codes are to do with the fuser. Call an engineer
Jun 04, 2009 | Brother MFC-8220 Fax
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Machine Error 71, Brother MFC 8440
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Sep 26, 2008 | Office Equipment & Supplies
Machine Error 17 Brother
I am assuming that you error listed above is actually a "Machine Error 71" not a 17 as their is no such 17 error. The error 71 is a problem with the Polygon Mirror (laser scanner). The scanner is going to require replacement. The part is available at Seattle Platen, Dale 1-800-221-2388.
Hope that helps you.
Feb 21, 2008 | Brother FAX-8360P Plain Paper Laser
Brother MFC 9700 All-In-One Laser Printer Logo
1,989 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
