I have an older jvc iart pro 48", recently there are a few lines through the picture, like the colour is bleeding or something.. Can i change a bulb to fix this?
  • 373 Answers
Can you elaborate on the description?
Posted on Mar 20, 2008
SOURCE:
Cannot boost yellow on screen
A few suggestions here--first if possible look into the lens of the tubes with set on--is one brighter than the two others? A loss of blue to some degree would mean yellow (red and green).
Also ( you may have to remove entire grill from front below screen) with set off make sure all 3 of the circuit boards that plug onto the bottom of the necks for each tube are not loose or one has not slid down a bit.
Jun 12, 2012 | JVC Av-48wp30 Iart Pro 48-inch Widescreen...
VC IArt tv doesn't show picture and the power button flashes
There is shorted component/s in the power regulator section to your TV. Check and replace them.
May 07, 2012 | JVC AV-27D302 27" TV
I have a 32" tv jvc iart and horizontal white
Hello
You are seeing vertical retrace lines. This faut is due to the vertical output section inside your TV. To rectify this fault, you must open your Tv. Just open it after unpluging it from the wall power socket. Locate the vertical output section on the printed circuit board.
It is easy to locate. You can see four wires goes from the deflection yoke; the coil fitted around the neck of the picture tube. Out of which two of them will be thick, usually red and blue coloured, and the other two will be thin. These two thin wires are for vertcal scanning. Just follow these two thin wires, and you will reach a point where these four wires are pluged onto the main circuit board, very near to the LOT. Upside down the printed circuit board, and follow the print of that two thin wires, and you will reach to the vertical output section of your Tv.
Before doing anything, just look for any loose soldering or bad solderings there. It is very difficult to find out loose solderings, as thay will be microscopic, I advice you to resolder most of the soldering points there by applying a little more solder; without making any solder short. Resolder all the pins of the vertical output IC, and see the effect.
If this does not help, replace the two or three electrolytic capacitors, at about 1000MF to 2200MFD there, with same capacity and voltage ratings. Make sure about their polarity, as electrolytic capacitors have both positive and negative terminals like torch cells. Note the polarity when resoldering them out of the board. This must solve ypur problem.
If you need anymore asistance, feel free to contact me through Fixya. OK
Wish you sucess.
Dec 11, 2010 | JVC AV-32F703 32" TV
Jvc AV-48WP30 iart pro the color on the screen is falling down on the left side the colors are not overlapping so it doubles what ever im watching
Replace your STK iCs, they are big black ICs will have the Part number on them example STK392-110
Mats has STKs 1-800-628-1118
Jul 02, 2010 | JVC AV-56P575 56" Rear Projection...
I have a jvc iart television and i had to transport to my apartment now i have green and red colors in each corners.. How do i remove those colors??
hello,
the problem is a colour patches , you can solve this by using a big size magnet like that in an audio speaker to remove the colour patches.
you do this when the television is power on, and gently moving the magnet towards the screen of television.
hope this will help...
May 21, 2010 | JVC AV-27F802 27" TV
Samsung rear projection hdtv flickering red
most likely the red CRT drive board has an issue, could be solder related
Apr 05, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC AV 48WP30 projection tv bleeding problem
You need two STK392-110 Convergence ICs. You can get repalcements at the following link, and they will provide free instalation instructions with picture so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 24, 2008 | JVC AV-48WP30 48" Rear Projection...
PLURED PICTURE
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 23, 2008 | JVC AV-48WP74 48" Rear Projection...
Jvc television want come on
Reset is done by unplugging the ac cord for a time,then plug
back in...............Please verify model number off sticker on the
                            rear of your tv...let me know.....T.
Oct 22, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Ekse
