Question about Tappan TGF320 Gas Kitchen Range
My oven will not heat up
The ignitor glows and the gas is flowing but it will not heat up. bought stove from family friend who has since died and the model number I found inside the hood is 282240A, but i think that is incorrect, for some reason I feel it is probably longer than that. Can u help?
  • 4 more comments
  • cyurlady Mar 21, 2008
    i have natural gas and yes it lights but does not heat the oven.
  • Anonymous Apr 06, 2008
    i have the same problem, how can this be fixed
  • zosopage Apr 08, 2008
    oven starter turns on but takes up to 10 min to start the burners
  • Anonymous Jul 01, 2008
    the igniter glows but takes a long time before gas comes on; now the gas does not come on at all.
  • William March
    William March May 11, 2010
    hi,
    it is possible that the stove may be set up to run on propane, do the top burners have a good flame height?
  • William March
    hi, does the oven burner light? and if so, you you have propane (bottle) or natural gas (city)?
    Scholar:
  • 110 Answers
This is almost always caused by a intermittent or bad oven ignitor, because it takes a min. of 3.0 amp draw to pull the gas safety vavle open to release the gas in the oven the burners on top you control by turning the gas valve manually. so you can have a cooktop that works perfectly but a oven which does not due to the different safety feathers
Posted on Jun 01, 2008
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
No gas flow to ignite
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 15, 2010 | Kitchen Ranges
Oven does not heat. Glow bar ignitor glows but no flame.
usually this means that your ignitor is weak and needs to be replaced. When the ignitor glows and NO gas flows through you need a new ignitor.
Jun 22, 2009 | Amana ARGS7650SS Gas Kitchen Range
I have a Frigidaire stove, model fgf316asa, and the oven does not heat. The ignitor still glows but does not ignite the gas. I cannot hear the gas coming from the line. What's wrong?
Hi, You should change the ignitor. Even tho it glows, the ignitor is to weak to open the gas valve. UNPLUG the oven. Remove the floor panel in the oven and you sill be able to see the ignitor. This is very common with gas stoves.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | Ovens
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Feb 08, 2009 | GE Profile JGS968 Gas Kitchen Range
Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Jan 13, 2009 | Ovens
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Magic Chef freestanding gas oven/stove - oven won't ignite and heat, stove works fine.
most common problem with gas stoves is a bad oven ignitor, doesyour oven usually "click" start?? or use a glow style ignitor?? do you have the model number??
Mar 17, 2008 | Kitchen Ranges
Tappan TGF320 Gas Kitchen Range Logo
173 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
