Question about Proton R5A Clock Radio
Proton P300 AM/FM Radio
Does anyone have a wiring or circuit diagram for this radio. In addition can the 110V AC radios be simply converted to run on 240V AC
  • grandray87 Oct 08, 2008
    Have just purchased a Proton 300...when turned on it started to smoke...no sound at all...lights work fine.....any thoughts? Thanks
    Ray
SOURCE: Proton Model RS-420 clock radio lost power back-up
The battery is located on the display circuit board at the front of the unit. It's a bit of a pain to get to.
You'll need to open the case, unplugging the wiring harness plugs so you can take the two halves apart. Next, remove the strip of circuit board at the top where the snooze/alarm and other top button switches are. Then you will be able to get to all of the screws holding the display circuit board to the front of the case. The battery is soldered to the board. I'm not sure what type or voltage it is, but it's probably a single-cell NiCd at 1.2v. I think the best replacement would be a supercapacitor but I need to figure out exactly what the battery is first.
It's a great radio that's worth fixing. If anyone can tell us what the battery is, please post! Mine says "860" on it.
Cheers,
- Phil
Posted on May 31, 2009
yammy_alf
  • 666 Answers
SOURCE: Proton 320 clock radio won't stay off. Comes back on by itself!
check power switch if not block and i good position. and also monitor by multitester if the continuity of that switch cut in off position.
Posted on Apr 13, 2010
  • 167 Answers
SOURCE: I have a proton 300 table radio and it has very poor reception.
I had this problem too, and fixed it by repeatedly and rapidly cycling the radio between AM and FM. Those buttons on top of the radio collect dust, which gets down into the mechanism and causes poor contact. Pushing the AM/FM button a bunch of times restores the contact. However, in my case this problem was an early warning of other problems to come: phantom turn-ons, etc. Eventually you'll find it necessary to take the unit apart and REALLY clean out all thos switches. I'm at that stage now.<!-- from fixya rte -->
Posted on Aug 11, 2010
  • 3 Answers
SOURCE: proton radio
I simply cleaned my red switch by spraying it with tuner cleaner and the problem went away (it will return in a few years and cleaning it will correct it again). The switch can only be cleaned with the radio open. A can of tuner clean/lub with a small straw will be needed.
Posted on Aug 28, 2010
Cytherian
  • 124 Answers
SOURCE: My Proton 320 radio has stopped working, although
Unfortunately, Proton discontinued these a very long time ago. There is not very much information available about them. The cause for the radio malfunction could be a number of things. One possibility is the switches. There is a foam gasket around the switches that degrades over time. If pieces of it get stuck inside the on switch, or lock the off switch, it would prevent the radio from working. You could try taking it apart and use a can of compressed air to clean out the switches. I had a problem with the radio turning on all by itself and the compressed air cleaning solved it.
Posted on Nov 07, 2010
I have a Midland VHF Marine radio mod 78-100 and I have lost the three pin power cord. anyone know the +/- configuration within the existing pin setup so that I can make another?? The cord is NLA.
I quickly checked the net for available diagrams and didn't find one for your radio. If you feel comfortable simply remove housing from the radio and check color of the wires and markings where those wires are connected to circuit board.
Feb 02, 2018 | Midland Boating
Need wiring diagram for delco car stereo model 16165893
I know how to wire it but it only show AM....it is not an FM radio?
Mar 16, 2012 | Ac Delco AM-FM Radio Cassette
2002 chevy pickup radio wiring diagram
I found the sollution for the radio and car Mp4 player with FM transmitter from the internet, however, I forget now. I am so sorry.
Feb 08, 2012 | Ac Delco AM-FM Radio Cassette
1998 chevrolet silverado delco radio backlight bulbs are not working. Removed faceplate for radio, which exposed a circuit board. Looks like this board will have to be removed to access bulbs. Has anyone...
The tiny light bulbs are indeed soldered to the front circuit board and a pain to replace. The bulbs can be had at Radio Shack, part # 7219 I did the ones in my Delco/Bose Gold radio in my Corvette, took all afternoon.
Feb 02, 2012 | Ac Delco AM-FM Radio Cassette
I have a used unit, need instructions on how to hook it up to a caddy 1995 factory am/fm radio
Are we talking a new deck/stereo or new speakers/subs?
A new deck will require a wiring harness (cheap at walmart or local auto place) and this will come with a set of directions and wiring diagram for your make/model vehicle.
Subs/Speakers can be wired into a stock AM/FM radio (though I have no idea why anyone would want to do this) fairly simply, The wiring diagram will be printed on one side of your stock radio letting you know where to attach the 12v constant, the remote wire, and the speaker wires.
May 09, 2011 | Car Audio & Video
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
The FM tuner picks up only a few stations and those are very faint. Two other Proton model 320 radios work fine in the same area. I live on Long Island where the reception is rather strong.
The tuning module within the radio is getween the base circuit card and the display. A shot of tuner cleaner into one of the ports will usually bring back the FM performace (I just got done diong my own). Also, it goes without saying that you need to make sure your radio still has its antenna wire and that the vacuum didn't eat it. If this is beyond your skill level, find a computer geek (there are few radio geeks any more). Commercial repair would cost more than the value of the radio.
Jun 11, 2010 | Proton R5A Clock Radio
Want to change my 110v plug on my dewalt radio to 240v
Your radio must be a import from the U.S.A. Your radio will not work on 240v YOU WILL BLOW IT UP!!! You need a step down transformer 240v to 110v to goto your radio, you will have to do a search on Ebay in Power tools. You sould notice the lead on your 110v radio is not like normal flex as its only single insulated for 110 volts.... Don't put a normal plug on or you may have to call the fire brigade!!
Nov 01, 2009 | Dewalt DC011 AM/FM Radio
Sharp wf 940 portable cassette / radio player
inside radio there is relay near power supply. change it and then radio will work. or clean it.
Mar 01, 2008 | Sharp CD-BA2600 CD Shelf System
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Proton R5A Clock Radio Logo
559 people viewed this question
Top Proton Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Proton Audio Player and Recorder Expert? Answer questions, earn points and help others
