Question about Sony Cybershot S650 Digital Camera
Cybershot 7.2 I bought this camera a month ago and now the lens is stuck. It won't retract or come out. Help!
  • Mike Johnson
    Mike Johnson May 11, 2010
    Has the camera been dropped or been around a beach?
  • 477 Answers
Where did you buy it sometime if you got it from places like bestbuy or other places like that some time you can take it back to them and they will replace it no question asked. I beleave they have a 30 day return policy on alot of their items. You have a damaged lens that need to be replaced other wise. I repair these camera all the time for the same issue. Hope this helps.
Posted on Mar 28, 2008
    Novelist:
  • 141 Answers
Cybershot 7.2 - print.gif The lens will not open, retract, or extend.
Follow the steps below to troubleshoot if the lens will not open, retract, or extend.
WARNING: There is a risk of hardware damage. Do not attempt to manually force the lens in or out. Doing so may damage the camera.
NOTE: Because each of these steps represents a possible solution to this issue, check the camera status after completing each step.
  1. Ensure the battery is adequately charged or connect the AC power adapter (if applicable).
  2. Perform a power reset.
  3. If the camera lens is still not operating correctly after completing the troubleshooting steps suggested, service will be required.
How to initialize or reset a digital still camera back to factory settings.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings. The manuals of some camera models may have instructions on how to initialize the camera, which is another name for resetting the camera to the default or original factory settings. Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to initialize or reset the default settings. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Otherwise, continue with the manual reset procedure below:
  1. Turn off the camera.
  2. Ensure the camera is not connected to an AC power adapter.
  3. Remove the battery from the camera for 15 seconds.
  4. Reinsert the battery.
  5. Turn on the camera.
NOTE: If the issue is not resolved by performing a reset procedure, service may be required.
Hope this is helful
Posted on Mar 27, 2008
Hi I slipped in the garage and dropped the camera when it was on==batteries came out and lens of course didn't fully retract. Put batteries back in and the green light comes on and beeps but won't...
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Samsung Cameras
Lens is stuck in the out position, it says to turn it off and on again, but that doesn't do anything. Can't take a picture.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Dec 25, 2009 | Sony Cybershot DSC-H3 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
I have a canon powershot tx1 and i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
I have a canon powershot a470nd i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
Jul 24, 2008 | Canon Cameras
Lens won't retract
The gears in the lens drive are stripped and need to be replaced. might not be worth the cost!
Jun 29, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Lens Wont Retract
mine does the same thing. i just bought it like 2 months ago too. what could it be? i don't want to have to ship it back, but it looks that way so far. i bought new batts. too and that did nothing. also i called sony, and spoke w/ tech support, and they had me take out the batteries, hold down the power button for 30 secs and then put the batts. back in. ??? i was like what will that do and she said reset it, but it still won't power on and the lens is out. it beeps like duhduh and then goes back off. it is making me mad. b/c also i have bought 2 sony PS2's and they both quit reading games. what is with sony? can someone help us w/ the camera problem? thanks!
Mar 24, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cybershot dsc-p73 dropped
I also dropped this camera from waist high and the lens was stuck out and would not retract or let me do anything. I ended up having it sent to Sony to replace the lens and it cost me $200. I paid $300 for the camera to begin with but to me this was the BEST camera I'd ever had and was worth it. Before repairing it, I bought a new Sony Cybershot DSC-W80 since the original one I had dropped was no longer available. I was NOT pleased with the quality of the new camera at all and it was supposed to be better than the one I dropped. That's when I decided it was worth repairing the broken one and worth the cost.
Dec 05, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
My Sony Cybershot lens is not retracting!!
The lens block needs a replacement and you need a good service center for this job. We can help you in spares supply. Do let me know as this is an expensive spare part. Sonyspares
Jul 31, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Sony Cybershot S650 Digital Camera Logo
95 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
