Wont play dics
My cd player wont reconize the dics
  • Anonymous Jul 31, 2008
    hts 3555/37
  • Russell Stewart
    Russell Stewart May 11, 2010
    What's the model number of the CD player?
DVD/CD-R error No disk in the tray Cd's Dvd's programming disks wont play with any program or media player, have uninstalled and reinstalled 3times both HL-DT-ST RW/DVD GCC4242N and drivers always...
You want to eliminate the following - Bad CD player or bad drivers.Get a buddy to down and burn the latest Ubuntu (Google it) Linux ISO boot file.Insert it into the CD and attempt to boot from it. If it boots then your hardware is fine.
Sep 27, 2011 | IBM ThinkPad T42p Notebook
Cd player takes dics in then says no disc
Certain CD players have not been designed to play certain formats of pre recorded audio CDs. Therefore check in your users manual what format of CDs it can play. Play those . Also make sure that CD sits properly in the CD tray with label side up. If the problem persists then you have to call the technician.
Aug 21, 2010 | Technics Audio Players & Recorders
Dics is loading too long and then rejected
then there is a problem with the lens get a CD cleaner to clean the DVD lens and after that if the problem persist then you have no choice other than to change the DVD lens .
Jun 03, 2010 | Samsung DVD-R155
Player freezes constantly, new problem
Take all DVD dics that freezes,get some dish washing soap wash the DVD dics laser surfaces to clean fingers prints, grims,dusts.Should solved this problems.
Mar 29, 2010 | Insignia NS-8PDVD
Won't play DVD's but will play CDs
I suggests to try another dvd dics maybe it is not compatible to your player. try universal dvd dics...
Apr 16, 2009 | Televison & Video
Dic
To make it play, you normally just push the play button.
If that does not work, often that means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
If that does not work, you will need to take apart the unit, access the lens pickup, and clean the lens directly, using isopropyl alcohol and a cotton sticks.
Oct 10, 2008 | NAD L40 CD Player
Cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Jan 28, 2008 | Tascam CD-A500 CD Player
Cd not playing
look for any damage of your dics, maybe some of your dics are scratched or has a dirty part. hope I helped you.^.^
reply me if still it has the problem. so we could proceed at the next step.
Jan 18, 2008 | Wurlitzer Jukebox Princess 120-Disc CD...
104 people viewed this question
 Grubhead
Grubhead
