Question about Sansui Audio Players & Recorders
Sansui rz 3000
The sound won't work
4 Suggested Answers
SOURCE: Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
Posted on Nov 08, 2008
dunnbiker
  • 8546 Answers
SOURCE: Please let me know the
http://www.springair.de/Sansui-RZ-3000_detail_13525_326_SESS-51aeaa5f0105cfe40d86469ac9c7cb85.html
In German but it says 2x80 watts. I'd guess 1980's.
Posted on May 28, 2011
dunnbiker
  • 8546 Answers
SOURCE: the receiver plays sound for
Sounds like a temperature issue.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jun 26, 2011
Sansui rz 9500 av ... there is not sound output from this unit. when I test the test tone... there is sound ... all the speaker is in good condition ... it work for the pass few week but suddenly not
Please check the settings and speaker connections. Do keep it unplugged then reset.
Sep 28, 2012 | Electronics - Others
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
How do I connect Subwoofer in sansui rz 5200 av model receiver?
You could refer to the instructions presumably available for the unnamed sub. THAT would determine the methods it can use.
Aug 17, 2011 | Sansui RZ-5200AV Receiver
I have a sansui stereo av receiver rz 7000 from 1990 which works on 110 220 230 volts and the receiver has a voltage selector on the back - I need to understand how to move the selector from 220 to 110...
Remove the fuse cover with a flat screwdriver, then pull the surrounding circular black plastic piec straight out and reorient it to show the desired voltage, then plug it in, insert the fuse and cap.
Nov 24, 2010 | Sansui RZ-8150AV Receiver
I have a Sansui receiver Model RZ-1000. The left channel is out. Cheaper to repair? or just buy another similar on ebay?
I have this unit. It is built with disable links for each of the channels, which are easy to replace. The replacement part is only a few dollars.
Oct 11, 2010 | Sansui RZ-5200AV Receiver
Solution for "code for unlocking a sansui VRDVD4005?
www.dvddemystifiziert.de/codefree_en/sansui.html
http://www.dvddemystifiziert.de/codefree_en/sansui.html
Sansui CDVD1900 / CDVD9000 / DVD 512 / DVD 939 / DVD 967 / DVX 2000K / DVX 2900 / DVX 3050PH / RZ-7100 / RZ8700AV / VRDVD4000 / VRDVD4001 / VRDVD4005 / VRDVD5000no known hacks
Apr 17, 2010 | Sansui VRDVD4005 DVD Player/VCR
612 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
