Zanussi IZ12 Front Load Washer Logo
Posted on Apr 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the bearings on my IZ12 washing machine please?
Edward Jennejohn
Level 2:
Sergeant:
  • Expert 244 Answers
  • Posted on Apr 17, 2010
Edward Jennejohn
Expert
Level 2:
Sergeant:
Answers
244
Questions
0
Helped
85296
Points
744
How old is it? still under warranty? if so, contact the point of purchase, or the manufacturer. if not, it's a hell of a job, and you may be better off replacing the machine! i don't know how old it is, but newer machines are (depending on manufacturer) more reliable, and less expensive for the value. your choice!
good luck!
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
8helpful
2answers
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
2answers
Error e51 on zanussi iz12
After wash clothes come out after wash they have dirty specs
if machine is noisy in spin cycle suspect faulty bearing seal. replace seal and bearings
2answers
1helpful
Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
1helpful
2answers
Fabric conditioner does,nt go into drum.
You need to remove the dispenser from the washer completely, and clean every bit of it completely give it a thorough wash and make sure that every bit is clean.
Get a strong thin piece of wire, and make a hook in the end, and then poke it into every hole in the top of the dispenser compartment to make sure none of the holes are blocked up.
This should solve the problem
Plz rate my solution.Thanks.
Drain pump for washing machine
the pumps vary a lot but if in the uk, pump cost is about £25 and fitting about £40 but why do you need a pump?
1helpful
2answers
Zanussi IZ12 Pumps, then Pause LED is flashing.
hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Zanussi FLE 1015W
Any solution yet ? same problem here Zanussi IZ12
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
