Question about Lexmark X4500 MFP Flatbed Scanner
Factory reset of X4500
Hi Jeremy,
I see that you have helped previously with the Lexmark X4500 MFP.
I have just been donated one and wondered if you could tell me how to perform a factory reset of the unit. The Administrator user/pass has been set and nobody knows what they are.
I hope you can help, and also I found your previous posts on the X4500 very helpful and I will be updating the firmware to 1.09 as soon as I have Admin rights.
Mark.
Hej Mark
**411 -> 4 -> 1 then the green go button
Regards
Daniel Knudsen
Posted on Oct 06, 2008
  • 1 more comment
  • peterkoehler Aug 01, 2011
    sorry - the password still exists.
    I can not get into the configuration menue, there is still a password required.
  • harald547 Aug 13, 2011
    Hi
    you can try to refresh the hard disk by entering # instead of green burtton after 411.
    Reset the NVRam (non volatlie) and the network configuration.
  • lorenjlemos
    lorenjlemos Mar 02, 2012
    "**411 -> 4 -> 1 then the green go button"
    What does that mean? do I press each of those buttons in sequence using the keypad to the right of the touchscreen? If so, when? I've tried this during the boot process, tried it during the loading bar titled "Initializing", but it doesn't seem to do anything.
    Would you please clarify? Thanks!
I was told that you can dial 976 on the keyboard during bootup.
Have nit tried this yet though.
Still trying to get a power supply.
Posted on Feb 18, 2009
How to remove hard drive lexmark x4500
Take off the Toploader adf, just pull it up.
Turn the x4500 upside down on the table, the adf unit hangig over the tables edge
loosen the 7 BIG screws on the bottom, which hold the metallic box
lift the metallic part up a bit, disconnect the groundscrew, the blue, red an mixed mini connector on the long side and the usb and the power connector on the short side (this one ist to disconect, with something getting under it an slightly pressure).
the the metallic box is separated and can be put on the table just lie the scanner before hangig over the edge.
there a two scres from the front an some 5 or so, from the top (which is originally the bottom...)
now turn the box upside down and open it.
Here we are, you see the harddrive, the cpu, everything.
Dec 15, 2011 | Lexmark X4500 MFP Flatbed Scanner
Tip
How to Remove entries (scan to profile) on Lexmark X4500
Hi
How to remove/delete unused scan to profiles entries on Lexmark x4500 flatbed scanners.
Javed.****@dva.gov.au
Regards
JB
on Jul 01, 2008 | Lexmark X4500 MFP Flatbed Scanner
Lexmark x4500 says unsupported left cartridge. I have checked it and it looks ok.
Try to clean contacts with a cloth napkin or cloth (and those on the printer)
Mar 10, 2011 | Lexmark X4500 MFP Flatbed Scanner
Looking for a service manual and schematics for the scanner.
http://www.lexmark.com/AP/service/info/multifunction/4036-304.pdf
download here
i hope this helpfull, please rate very helpfull or helpfull if you think this helpfull
thanks for using fixya
Jan 20, 2011 | Lexmark X4500 MFP Flatbed Scanner
I turn on my X4500 scanner, It begins the inialization, gets to 100% and just sits there. It does not progress any further.
Usually that's a network problem, try doing a factory default of the network base hold the right and the check button "go" button til you see the menu for maintenance then look for network restore part, do a factory default of the network and then restart the scanner again after the printer starts up again
should be good to go
Dec 17, 2010 | Lexmark X4500 MFP Flatbed Scanner
The touchscreen does not respond to touch
Try these steps:
  1. Turn Printer Off
  2. Turn the power on and immediately press 1 or 2 repeatedly.Continue until the following message appears:Press the # button to perform disk maintenance (35+ minutes). Otherwise,press the green start button to continue.
  3. Press # to begin the disk refresh process.This process may take as more than 30 minutes, but frequently only takes 10-15minutes. A message will appear on the screen indicating the refresh is in progress.
If problem continues:
  1. Try dial **411
  2. Select 4 MFP settings
  3. Select 1 Restore Factory Defaults
If still problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for further assistance. Thank you for choosing Lexmark.
Aug 27, 2010 | Lexmark X4500 MFP Flatbed Scanner
OPTIONS
Unfortunately this unit will not even completely start up without the appropriate Lexmark printer.
Jul 16, 2009 | Lexmark X4500 MFP Flatbed Scanner
Does the X4500 work as a stand-alone scanner
The X4500MFP requires a compatible Lexmark printer in order to do any functions.
Nov 14, 2008 | Lexmark X4500 MFP Flatbed Scanner
Administrator Password Reset to factory default
Hey
have you tried to reset the whole printer to factory defaults
Regards
Daniel Knudsen
Jan 12, 2008 | Lexmark X4500 MFP Flatbed Scanner
Can Scan A5 size duplex
The software on my X4500 unit allows duplex scanning of A5 paper. Updating the firmware and software is fairly easy if you need to.
Nov 20, 2007 | Lexmark X4500 MFP Flatbed Scanner
Lexmark X4500 MFP Flatbed Scanner Logo
1,785 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
