Question about Sony CDX-CA760X CD Player
Hooking up the Sony CDX-CA760X CD Player to a ipod
Hi
How do you get this unit to change into AUX mode? I have the sony Ipod adpter hooked into the bus inputs into the back of the unit and also the controller plug ...I'm getting nothing...Help...thanks ..Mike
  • zexisgood May 08, 2008
    Help have the EXact sma eprob have the y adaptor for the rca in for the ipod for the rear but cant get it to switch to anything but Front aux in how do i get it to switch to rear aux in?
5 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Posted on Mar 15, 2007
KaeZoo
  • 156 Answers
SOURCE: Linking an i pod to a Sony CDX-MP40 using the bus input terminal
Some Sony head units let you use the Bus audio inputs as an auxiliary source input, but yours is not among them. To play your iPod through the head unit, you'll either need an iPod interface module: http://www.xplodsony.com/xplod/accessories/XA-110IP or an auxiliary input module: http://www.xplodsony.com/xplod/accessories/XA-300 The iPod interface will allow you to control and display the iPod directly through the head unit, while an auxiliary input adapter will allow the iPod to play through the head unit using the iPod's controls and display.
Posted on Jun 04, 2007
KaeZoo
  • 156 Answers
SOURCE: Having problems hooking up an ipod.
The "bus audio input" works as an auxiliary input on some Sony decks, but not all. For the others, you need an auxiliary input adapter like this one: http://www.crutchfield.com/S-Yln489DwSWp/cgi-bin/prodview.asp?i=127AUXONS You can also use a Sony iPod adapter that will charge the iPod and let you control it through the head unit controls: http://www.crutchfield.com/S-Yln489DwSWp/cgi-bin/ProdView.asp?g=305250&I=158XA110IP&search=sony+iPod
Posted on Jun 22, 2007
SOURCE: I can't use my ipod.. pressed SCR and only tuner and standby is displayed
Yes i had a very similar problem.
I have the MP-235. I could not edit my clock, my subwoofer settings werent active, and I could not switch to AUX.
If you have these problems, you have to hold down the menu button (bass boost) to enter the menu. then scroll around, turn AUX on, change the clock, etc etc.
You turn demo mode off the same way. Kinda silly how they have it all set up.
Hope that helps anyone in the future. i just wasted 3 hrs with this crap!
Posted on Dec 27, 2007
SOURCE: Sony CDX-L480X
cAN YOU TELL EXACTLY WHERE U CONNECTED AUDIO IN?
Posted on Feb 14, 2008
Try change my car radio cd .after connecting electric power and audio cable the new radio panasonic start 1 minute and stop loss power i reconnecting the old car radio ask me for cood the car is
You need to enter the radio code.....this should be with the service book or handbook, or contact the main dealer who will have a record of the code!
Jan 26, 2015 | Car Audio & Video
Tip
Some information of DVD player for Audi A6
Audi always be a kind of luxurious and comfortable car, but the technological develop fast , the original function can't not meet the driver need now. So the special made Audi A6 DVD player come out. There is some information of Audi A6 DVD player for you.
The outlook of Audi A6 DVD player match the Audi completely. People will not think that the Audi A6 DVD player is not the original DVD player. The resolution of 800*480 will display the high effect of picture for you. The operation system and capacitive touch screen always make the operation easily.
The Win CE operation system can be operated easily. The Audi A6 DVD Player can react quickly. And the you can play audio and video by most of format. It will provide a high quality display for you. The Bluetooth function also help people a lot. If you want to connect some device you can find USB port in the side of Audi A6 DVD player which is the place you reach easily. you can surf by WiFi and 3G internet.
Hope these tip can help!
Audi A6 DVD Audi A6 Navigation Audi A6 GPS Audi S6 Navigation Audi RS6...
on Jun 17, 2014 | Car Audio & Video
Where can I find the connections the go on the back of the stereo
Usually behind the stereo in the console. Either a square or rectangle in shape. You can obtain adapters for differing units that allows the use of the original wiring harness without rewiring. Just a simple plug and play option.
Jan 01, 2015 | Car Audio & Video
My 2002 mazda mvp ausio system is not working but I can insert and eject the CD but cannot do the in tape cassette also the display is not showing the clock or any thing plz any one tell me whats wrong...
Internal board damage. Also the ribbon cable for the soft load on the cassette is not engaging. This can happen due to just ware from the age of the unit. Cold solder joints are usually the culprit, that is why the display will not light. Check yards for a newer used deck it just might be easier unless you have a shop you can send it to.
Nov 10, 2014 | Car Audio & Video
I need the power plug wire harness that u hook the speakers up
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Electro help
My ripspeed incar dvd player has got no picture but has got the sound what can i do to make this work
First thing comes to mind is a possible update to the system. Have you had it for a while now? If so, you should go to the computer and go the maker of the unit. Check under software updates or downloads to see if there has been a remedy or fix that the maker has published, if so...then do as it says to do and see if this resolves the problem before you get into the actual technicals of the unit. It may need nothing more. I hope this helps.
May 18, 2014 | Car Audio & Video
DVD won't place discs
Did that just begin out of nowhere? IS the Dvd spinning, if you listen closely and the player is making noise as well? That would be the lens trying to get a read on it but if it's scratched (I'm sure you tried others) sometimes the lens just go bad out of nowhere...Mu original 500 Sony PS1 in 1998 lost its lens about 3 months in...I can't think of anything else right this moment....I hope you fix it...
Mar 23, 2013 | Car Audio & Video
Can't switch to the auxiliary
try useing it.. plug your aux cord into whatever your using (mp3 player) as maybe your radio won't switch to aux until it senses that there is audio being played through the input aux cord?
Mar 20, 2013 | Car Audio & Video
How to set clock in 2000 GMC JIMMY
Owners manual: 3-10:
Setting the Clock for Systems with HR and
MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode.
SET Button
Press SET. Within five seconds, press and hold the
SEEK right arrow until the correct minute appears on
the display. Press and hold the SEEK left arrow until the
correct hour appears on the display.
Nov 13, 2009 | Car Audio & Video
Sony CDX-CA760X CD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
