Question about Polaroid FLM-323B Television
Lcd tv magnavox
White screen no picture, help
LOSES PICTURE AT TIMES....CHANGING CHANNELS USUALLY SOLVES THE PROBLEM, BUT IT MAY OCCUR AGAIN AT ANY TIME......NEVER LOSES VOLUME
  • lightweight0 Aug 27, 2008
    can hear the voices but screen is totally blank
  • Anonymous Dec 19, 2008
    i have the same problem i no this is a bit drastic but i hit the back of the TV and the picture came back maybe its a loss connector or something
  • 3 Answers
You might have a timer set on the options menu. look under the sleep mode.
Posted on Mar 25, 2008
Why does my TV on when the power button is off?
You need to spare yourself a lot of frustration and just replace the TV
Jul 13, 2016 | Astar Magnavox 19MD358B 19 in. LCD TV
32 inch LCD TV samsung series 5
If there is sound, no doubt, its signal input is OK. The problem must be to your Tv itself. If the LVDS cable, the cable that connects between the T'Con board and LCD panel have a loose contact, this type of faultcan occur. Re-seat this cable once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Hundred Thousand viewers cannot be wrong.
May 05, 2013 | Televison & Video
My TV turns on, has a blue screen but won't recognize anything - my DVD player or X box. For cable I can get volume but no picture after completing TV set up from menu but once I turn it off the TV loses...
Now tv turn on,tv get a picture only flashes few sec.than died have sound left only?Yes,than the tv long board call the LCD inverter board is dead.This long LCD inverter board help the LCD screen panel to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long refurbish LCD inverter board for the replacement.
Nov 20, 2010 | Polaroid FLM-1514B LCD TV
The picture of my Philips Magnavox big screen tv it sort of faded and dirty i cleaned the screen multiple times and it still looks the same... any help?
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 30, 2010 | Philips Magnavox 51MP392H Rear Projection...
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
My magnavox 37" LCD tv does not have a picture but dose have sound,I can not get my menu or AV on screen
Thank you for posting your question on Fixya. There are some simple diagnostics you can do that will help us find the problem
1)Do you notice a flash on the screen before the picture goes out?
2)Turn on the set and darken the room. See if you notice a dull glow on the screen. If there is no dull glow then
3)Take a flash light and flash it on the screen from a close distance. See if you notice a dull image on the screen. Keep changing the channels to make it more noticeable.
Let me know your observations.
Sai.
Jan 24, 2010 | Televison & Video
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
My Soyo DYLT032 has power but no picture or sound
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
May 30, 2009 | Soyo DYLT032C 32 in. LCD Television
No picture (white screen)...
its a video cable or LCD connectors. remove and re-connect again.
May 27, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
Magnavox 30MF200V/17 No picture, only sound
Do you know if i can use an inverter from any LCD tv, or does it have to be specific to that model? I was thinking about taking an inverter from another broken TV.
Dec 31, 2007 | Televison & Video
Polaroid FLM-323B Television Logo
76 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
