Question about Polycom SoundStation
Comcast Cable Modem with Polycom Soundstation Premier
My Polycom SoundStation Premier conference phone will work one time when I first hook it up through my Motorola SBV 5220 Cable Modem (from Comcast) Then it won't hang up. If I leave it connected, it is as I have left it off the hook. Is there another device i need to hook up to get my phone and Polycom unit to work through this cable Modem? Thanks!
dv8nights@comcast.net
    Guru:
  • 1,049 Answers
Try adjusting the ringer volume, dial tone volume, and speaker volume. Make sure that the ringer type selection is not set to off. Also make sure that you are not bridging your call.
You can also use the Upgrade feature built into the phone to look for updates which may resolve your issue.
If this has only started happening recently, Restore the default settings and see if it resolves your issue.
Posted on Oct 01, 2009
I need to get the connector color code for a Polycom Soundstation conference phone.
From bottom of connector (not clip side)
Black
Brown
Red
Orange
Yellow
Green
Blue
White
Feb 08, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
I can not get a dial tone on our new soundstation 2W I have unhooked one of our phone lines in our office so the line is good but does not work on the soundstation but works on our phone. When you try...
You need to update the software on the device. I called their support line and the tech explained everything. This has been a common problem with this conference phone.
Feb 07, 2011 | Polycom SoundStation 2W (2200-07800-001)...
I need the color code of the conference phone from the adapter to the phone
Does anyone have the color code to the Polycom Soundstation connector? The end fell off and I want to crimp on another.
Thank you.
Jan 28, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
What is the station type to use when hooking this polycom sound station premier EX to an Avaya S8300 on a digital port card?
The Polycon Sound Station Premier coference phone is an analog device. You need to connect it to an analog port on your phone system.
Dec 13, 2010 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Usin for an internet conference
You need to buy a Computer Calling Kit from Polycom. That is essentially a cable with a 2.5mm connector to the Polycom Soundstation 2W on one end and two 3.5 mm connectors to the PC Sound card end (one to the Microphone port and the other to the Speakers port).
Mar 08, 2009 | Polycom SoundStation 2W (2200-07800-001)...
Conference problem
repeat you setup for all station you want to connect to it.
Sep 18, 2008 | Polycom SoundStation
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Polycom SoundStation Logo
492 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
