Question about Refrigerators
Roper Fridge problem
I heard a pop like you'd hear in short fuse with a little spark I suppose coming from the refrigerator. When I went to check I noticed that around the plug there was a black imprint and it wasn't working anymore. I unplugged the fridge and tried other outlets near by but no luck.
I am a renter, called the superintendent, no answer. I have lots of food in it and would hate to see them go bad.
I'd like to fix it myself if it's possible or have it repaired rather than waiting for a response from the super.
I reside in 10024 area in Manhattan. If you can help me to find a repair service close by or even better how to fix it I'd greatly appreciate it.
Thank you very much in advance.
    President:
  • Refrigerators Master
  • 2,651 Answers
You tried ither outlets andthe refrig wouldnt work??? or the surronding outlets didnt work??? if the refrig "POPPED" the outlet and surronding outlets sounds like you have a direct short within the refrig somewhere. no real quick fix for sucha thing other thtn physically checking all components looking for where hte trouble occourred
Posted on Mar 21, 2008
SOURCE:
Replaced bulbs in my Viking DFS423B and still not coming on.
That was a DEAD Electrical short. If your talking about all the bulbs, it's probably at a fuse box. Start by checking all the fuses (under the hood too) Ck all the fuses anyway and that's the circuit where the trouble started if you find a bad fuse. More than one or two fuses your best bet is pro help unless you have wiring diagrams, test light & multimeter. Also look for burn marks on the wiring where you heard the POP.
Sep 24, 2015 | Cars & Trucks
My roper refrigerator has a freon leak can i repair it myself?
I would say You need new fridge. Roper fridge will cost less then repair, because You will have to call refrigeration company. Job is costly, would estimate at 500$-1200$. Hope that helps!
Aug 19, 2015 | Roper Refrigerators
Fridge keeps tripping breaker and I hear a loud pop
Unplug and keep unplugged until the short circuit is found. COULD BE:
Line cord coming in is bad. A wire is bare touching chassis. A shorted motor capacitor. A shorted Compressor. A shorted wire to cooling fan. You could start a fire or get shocked, be careful.
Dec 05, 2010 | Refrigerators
Light bulb blew out. Put in replacement bulb, which will not turn on in frig, but will work in a lamp. Is there a fuse top replace or a circuit breaker to reset?
No there is not a fuse I am sorry to say, you are probably dealing with a broken wire or shorted socket. If you are brave you can unplug the fridge and remove the screws holding the control box(plastic casing the light is set into) and check the 2 wires going to the light for breaks or burns. Also make sure your door switch is opening and closing to allow the light to come on.
Jan 19, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Instrument panel out
Normally when you hear a pop noise thats a fuse giving up heh. If you lost all lighting control i belive you popped the 50amp fuse located within the engine bay in fuse box located above the battery.
May 22, 2009 | 1994 Lincoln Town Car
Roper refrigerator--water accumulating in bottom of fridge
on some refridgerators the plug at the bottom inside either turn out or lift up,be gentle either way,probably plugged just under it
Apr 08, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge not cooling
How old is your refrigerator? Is it still under warranty?
Jun 18, 2017 | LG LFD22860 Stainless Steel Bottom Freezer...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
